Hi guys,
It looks like I need a radiator for my S2 Stagea, the one in the car is leaking.
I've done a search on the forum but was unable to find a part number for it.
I found few topics here where people were talking about several options (ebay, koyo and so on). I would prefer direct replacement and put a standard or better one, but I dont want to go for manual radiator + external tranny radiator. might be the better option from performance point of view, but at this stage I prefer to "keep it simple" :)
So, my question is - what (and where) do I need to buy? Should I look for S2 radiator specifically or R33 or stagea S1 radiators can be installed ? 36 mm, 40 mm or 52 mm ?
They were talks on the forum about ASI radiators from ebay, like http://cgi.ebay.com.au/52mm-Alloy-aluminum-radiator-skyline-R33-RB25DET-GTS-T-/280580988112?pt=AU_Car_Parts_Accessories&hash=item4153ee1cd0. They are well priced ($199 delivered) but I am afraid they suit manual cars only. Am I right ?
Any help will be appreciated :)
https://www.sau.com.au/forums/topic/351768-radiator-replacement-help-needed/
  • Replies 42
Posted Images
why dont u get the 1 u have now repaired?
natrad or some1 like dat should be able to do it. other wise just talk to a nissan dealer
From my experience, the cost of repairing the unit is not that much lower (I might be wrong). Plus you end up with old unit, and you never know how long it will last.
Nissan dealer is obviously an option, and I will approach one tomorrow. Just want to know what else can be done.
I am sure the correct answer is the obvious one. Go your radiator shop and ask for a new one. Even if they have never heard of a Stagea they should be able to look through their Natrad catalogue and find one for you. They simply match the shape, position of the inlet & outlet make sure it has the heat exchanger for the autoetc and they should come up with the right one.
My radiator packed it in this week aswell, new one from Nissan is 700 bucks and 3 weeks wait, I got lucky and got a second hand one from just jap so maybe call around and ask if anyone has one otherwise like the others said upgrade to an alloy radiator and get a separate transmission cooler as if u have to go through Nissan in the end cost will end up similar anyway so u may as well upgrade, alloy radiator from just jap is 300 bucks don't know about trans cooler though, oh and if u check out the first page of the parts list someone mentions replacing their radiator with an r33 one and quotes a part number if that helps
Edited by Chris_Beli
alloy radiators are good for cooling bit i know by fitting lots when i worked at jshop
that they also crack easy
nothing beats a stock 1.
i would take ur old 1 to natrad and see how much its going to cost to fix.
they can also flush it out and pressure test it
cant hurt to try.
Unsure of what State OP is in, but in Adelaide we have JayRad who sell Denso parts; I took my old (auto) radiator to them and they measured it up and found a replacement with trans cooler but ~2 inches thick overall (original is about 1 inch thick I think from memory, a bit undersize IMHO). The new unit was somewhere around $300-350.
Hi Dave
my stock Rad is 16mm thick,
we have sorted new one 25 mm core,
will post more Details for all,
but as this is WA it maybe good for any one looking this side,
Cheer`s Chuckie.
well its sorted 25mm thick core, jap made,
fitted with 1 years warr, flush & coolant $400 ,
ANDERI will post more info soon,
this is in WA :cheers::thumbsup:
so hope you boys can get sorted in EAST :3some:
    • Hi guys my 94 r33 gtst fuel pump has gone out. I have a walbro 525 ready to go in but am unsure if I need to upgrade the fuel tank bulk heads? Ive heard that others have issues with the stock wiring melting... Ive seen alot of people recommend this: https://frenchysperformancegarage.com/products/fpg-nissan-skyline-r33-r34-silvia-s14-s15-billet-fuel-tank-bulkhead-hat-top-an6-with-high-current-connector-apex-2-8-delphi-fpg-100?variant=42873255198898 My current pump that stopped working is aftermarket but I had no relay mod or upgraded connectors. Need some advice please. TIA
    • It’s new. It’s the cd009. I did take the transmission apart to mill down the bellhousing and had both housings come off the gears so wondering is something isn’t in right. I am running redline. I can get it in gear running too but it’s just not easier and it’s almost like 2, 4, 6, and reverse all the back gears aren’t happy going in
    • I’ll remember that as a last choice. It’s brand new
    • Got keys and did a walk around the yard planning the landscaping works with the family that I will be doing Main effort: remove all the woodchip in the gardens that are around (attached) to the outside of the house and replace with 10mm blue metal, having woodchip close to the house is a recipe for inviting white ants, currently there are no white ants within the block and I would like to keep it that way I'll be buying some large raised garden beds to grow veggies and stuff, and the woodchip will be mulched with everything else that gets dug up, pulled out, or cut down during works Next will some minor drainage and landscaping maintenance up one side of the house, where the fuse box, AC, and solar stuff will go, about 12 mtrs long by 2 meters wide, I'll break up the soil, add gypsum and then I'll dig in a French drains about 300mm deep x 300mm wide and fill it with agg pipe and blue metal, then level out the whole area with a 50mm layer of blue metal, the soil, whilst currently pretty compacted, will break up well with the gypsum to aid in drainage, I'll then cover the area with a 50mm layer of more blue metal In saying this, the drainage issue is minor, but that little hidden away area down the side is untidy and weedy, and as all of the main elec stuff is there I want it neat and tidy to appease my OCD Again, the material excavated from the French drains with be added to the garden bed mulch, as will some rose bushes and some other crap looking garden plants, and a old apricot tree that is looking worse for wear The apricot tree is currently in a little roundish garden bed that is in the middle of the back yard with few other crappy looking plants around it, that will all be removed, levelled, re-turfed, and is a perfect spot for a hills hoist There is also a area about 3m x 2m between the rear fence and shed that will get some attention, it looks like some stuff was stored there and the grass is dead, that will also get broken up and mulched, and is a prime spot for a pumpkin patch I've guestimated that I'll need: 3 tonnes of blue metal, 12 meters of agg pipe, 5kg of Gypsum, and a hills hoist, so a few bags of concrete as well to set it in place (the house currently has one of those pull out 4 line jobs, whilst it works, I want a retro old school hills hoist), I am also going to run some chickens, there's a great spot for a coop, so a chicken coop to suit 4 of those lovely egg laying bitches will also be on the job card That should keep me busy for a while, and will finish off the back yard ready for a early spring planting of some veggies and berries  Once the main effort is done I'll start out the front, there's a large rock garden that could use some TLC, but that is only minor works Should be fully moved in within 2 weeks, the landscaping works will start then Fun times, retirement is good
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
