  • Replies 42
Posted Images
Installed my R33 S2 auto radiator into my mums stagea series 1 with no issues and got myself a shiny allow one since I dont need the auto radiator anymore.
So from experience the R33 radiator works fine in the series 1 stagea.
Edited by LiQuid IcE
Yeah I wanna keep the cooler though, I have been on the look out for a standard 33/34 auto rad. I think the core is 25mm thick and I could retain the cooler/warmer. I had no luck getting second hand ones so I was gonna get one off eBay but for the price chuckie got his seems like the better option.
I just picked up a factory replacement koyo radiator for 350 will put it in this weekend and see how things go, it's allso automatic, couldnt be bothered going bigger then adding warmer/cooler and the fact that the factory koyo is half the price of the full aluminum rads.
Hi guys, my apologies, they blocked access from work and I was fairly busy recently (and bloody card reader stopped working !!)
Any way, as guys said, I got it from John for around $400 fitted with warranty. Cooling system flushed, new coolant, all checked. It almost twice as thick as the old one .. but look at the pics, they speak for themselves.
I'm happy. IF I KNEW how thin was the old one, I'd change it long time ago - every now and then I go up north and I've seen +48.5 outside, going 100+ (well.. ++ :-)), loaded car, aircon on... I'll feel much better from now one..
Probably we could the radiator slightly cheaper, but I'd agree - for extra $50 someone does all the work + coolant + flush + testing + warranty + running around. $50 well spent.
Edited by And
  • 1 year later...
Hi All,
Just noticed a crack in the top of my radiator and cooland is now leaking out....
Anybody have the part number for the above KOYORAD replacement or know of a distributor in sydney??
Thanks Guys.
Adrian
Got mine off eBay, $220 ish no regrets (had an alloy on in between and it was junk)
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
