Whaddya reckon?
made it to use as a sig in another forum (maybe this one too). Just messed around with an old promo pic of an R31 and some wheels pinched from an R32 GT-R promo photo.
*EDIT* finally figured out how to get the source, so no more AF link!
https://www.sau.com.au/forums/topic/35177-r31-skyline-gts-x-photochop/
