R33 Catback Titanium Exhaust System - Jap, 3" & 4.5" tip, 2 mufflers, no cat, very deep note, not too loud.
This came off my R33 GTR VspecII. Not sure if it will fit GTST's.
Pickup from St.Lucia Brisbane, call Michael on 0413504084.
Price: $900
post-28547-0-12717400-1296036278_thumb.jpgpost-28547-0-82326300-1296036298_thumb.jpgpost-28547-0-97653900-1296036344_thumb.jpg
  • Like 22
  • Nope 3
will this fit a r32 gtr?
Just rang my friend, he said it will fit a 33 GTST, but he reckons the length/hangers will probably be wrong for 32, but it might fit a 34.
  • Like 22
  • Nope 3
that looks like a legalis R, not their titanium one, which looks pretty different
Can you confirm what it is from the numbers stamped on it (shown in the pics?) at all. I am not 100%.
The muffler bits have that blue titanium shine but the pipe section just looks like s/s?
  • Like 22
  • Nope 3
  • 3 weeks later...
but you don't and never have owned a r33 gtr.....
  • Nope 1
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
  • 3 weeks later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
