Canon or Oval Muffler
53 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I currently have a canon muffler but, not a big fan of the noise it produces. So I decided to uses the Varex X force muffler with a remote volume.
I just want to know peoples opinion on a oval or a canon.
Question is would you use a canon even though its defect-able or use a oval muffler to stay out of trouble?
True once I install this muffler its silent so it wont matter but, sometimes the cops are just a**h***s so, just want to stay out of trouble. The main reason is a I drive my R34 GTT as a daily driver so want to keep the noise down especially if I want to have quiet drive.
In my eyes canons are the best looking things for a sports car but, they are the most eye catchy thing with a car especially with a cop behind you.
After your opinions I will order the exhaust, Thanks for any advice or assistance given.
https://www.sau.com.au/forums/topic/351820-canon-or-oval-muffler/
There is no reason a proper muffler, cannot be legal, look stealth and be reasonably affordable.
Varex cost more, are still deflectable and I'm yet to hear one that gives a decent exhaust note.
I really can't see how they offer anything.
As for the tip, just have it the same size as the exhaust itself. If its 3", just a 3" tip.
This also helps reduce drone and noise.
Otherwise just go twin tip muffler looks much more factory if that's what you want.
ive got a cannon on my car, its quite and sounds awesome when on full boost. when cruising its quite as, it depends what kinda of cannon you buy and what eles you have on the rest of the exhaust.
iv got a fujitsubo oval muffler, sounds great, not tinny or farty in any way... from my experience an oval muffler does sound better... to me anyways. Cannons sound a bit tinny to me and not as clear as a oval muffler, it doesn't really muffle the sound if you know what i mean... lol
Get the biggest straight through muffler you can fit in the original muffler cavity and put a dump pipe on it. The dump pipe directs a lot of sound down at the ground making it sound more quiet if you stand behind it unlike cannons which blert out sound like a megaphone.
It's a good idea to get it tucked up in the original muffler cavity neatly beacause cops love nothing more than seeing a 3" exhaust hanging out on an angle at the back, lookng like it could almost scrape the ground.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
