L28&l20 Turbo Motors
L20det complete original running motor Exedy heavy clutch short nose box all in very good condition
only mod is a high flow r34 turbo stainless split dump and front pipe all in perfect condition.$1500
L28 280ZX Turbo motor Reco P90 head new TO4ETurbo Dump pipe to suit F54 block new 5puc button clutch
280ZX Turbo box, Wolf3D ecu wiring for R30$2500 complete drop in motors with clutches boxes etc etc.
Both in very good condition no faults.
No silly offers may separate bits if enough interest but price will differ from complete set ups.
Selling to fund a different Enging combo
Make offers will deliver for fuel & time depends how far and convenience.
0415 346 073
Very interesting old dude,
I am not currently in the market, but will be in the future.
"high flow r34 turbo stainless split dump and front pipe all in perfect condition"
Would you consider selling this as a package? (Trade in for stock L20et Turbo and dump plus cash?)
Estimated or if known RWHP of each engine and what car they were in?
The L20et is out of a HR30 gt RWHP not much factory 144 this has bigger injectors
bigger turbo and split dump pipe so probably a bit more.Good thing its all original
and in excellent running order also the ECU will go with it along with all the Factory
Turbo stuff.
The L28et came out of a 280zx so all factory turbo stuff except injectors turbo dump
ECU new clutch ass might even throw in the same side inlets front mount and piping
Clutch Turbo head have only done a few hrs work this also was in the HR30 after the L20
but like i said I'm going a total different way and what ever i get for it all will be
put to that.As to RWHP 250+ maybe not really interest in figures as there not big enough
to talk about but plenty more than the L20 and when it boosts it's fun.
Edited by old dude
You mention the L28 went into the R30, R30's like C210's use front facing sump L's. did you change sump back to the Z one when you removed it from R30?
Yes mate! I put both sumps back on there original motors
I plan to, just wondering how difficult making pickup longer is and if there's anything else involved.
Edit: Can standard ecu still be plugged in or have pinouts been changed?
Hydraulic lifters or solid?
Edited by Socrates
How difficult was sump swap?
Was only a case of elongating the oil pickup and bolting on a front facing sump?
It's not a biggie. My car's oil pick up (originally from a 260z???) has been cut, pointed in the opposite direction, and welded again to suit an 280zx sourced L28 with a C210 sump.
I can confirm that you will need to modify your oil pick up, but don't expect a major hassle. Better news, your front facing sump bolts straight up to the L28 block. The biggest hassle you might face is deleting one of your 2 dipsticks (a sawn-off dipstick should do the trick).
Again, from my experience, 144HP odd at the rear is going to feel like you're in a rocket compared to standard C210 arrangement... as for 250 plus... that's actually an awesome number, being near on double the factory output, but possibly waaaay more poke than the original C210 drivetrain and brakes are going to cope with for long. Fun though!
its 144 HP at the Flywheel.
My auto L24e with microtech was 74kW and went harder than a mates stock 5 speed L20et.
as for pinouts, each engine and series and release year and even continent has a difference or 2.
The later the release date the better, well nearly. You could get stuck with the ECCS with Oxy sensor and Cat convertor... meaning emissions compliant.
That's interesting!
My factory spec L20et 5 speed Paul Newman with it's 144HP, pulls up Mount's Ouseley & Kiera coming north from Wollongong @ 90kph in 5th without a care in the world with 2 up.
My old 7MGE MX83 auto Cressida couldn't do that with just me on board, unless I held it in 3rd to stop it jumping up to 4th & back to 3rd all the time.
And when I took it up the mountains the other week, it kicked ass going up Lapstone Hill off the end of M4 at Emu Plains.
Anybody that knows these roads in NSW can vouch that it is no mean feat.
Cheers, D
Hey old dude, you still here?
How much for postage/freight to Duncraig Perth, WA.?
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
