hi
i am selling my r33 gts n/a, pics up soon
rego till late febuary
hks hyper d coilover suspension
nardi steering wheel
oem rear strut brace s2
5 speed manual
colour is black, flush fitting fibreglass bootlid, matte black
has oem s2 sides kirts and pods, has black headlights(from turbo model)
zepter 3 piece wheels, good tread on tyres
has axpei exhaust
it is 2.0L model, doesn't have hicas
$5500
thanks, josh 0412788262 (i work afternoon shift cannot take calls from 3;30pm)weekdays
  • Like 1
https://www.sau.com.au/forums/topic/351860-r33-gts-non-turbo-black-manual-20l/
the silvia is out of rego, its a pig
but i will register it if the skyline sells, otherwise it will become a dedicated track car
i can't afford to keep 3 cars in rego
and yes the r33 is rb20e, 450kms to a tank street driving
good points
tein super drift coilovers
momo mod08 steering wheel
bbs 17 forged wheels
brembo evo front brakes, r32 rear brakes/handbrake set-up bm57 brake master cylinder
5 stud conversion
acrylic windows
spoiler removed
vertex front bar, nismo side skirts, supermade gentlemans rear bar, smoked taillights
bad points
ca18de engine
i have a s15 sr20de+t engine to drop in
  • 1 month later...
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
