Nissan Skyline R32 GTS-T Type-M
Year: 1992
Engine: RB20DET
Transmission: Manual
Kilometres: 193xxx genuine kilometres on the shell, 140xxx kilometres on the engine.
Price: $13,000 NEG doesnt sell at this price i will part out, please dont ask for parts until then
History: I bought this car around 5 years ago now as a non-turbo. About 6 months later i did a full type-m turbo conversion on it including: complete RB20 engine, full 5 stud conversion with bigger brakes, full interior swap to type-M.
I haven’t had any major problems with the car, the radiator went on me at one stage which was replaced with a completely brand new one as well as gates racing hoses and a new thermostat. I also rebuilt the gearbox due to a really noisy thrust bearing.
The car was resprayed around 8 months ago at DT panels as i put a GTR front on it and the paint was fading anyway.
Rego expires in September so got a bit of rego for Victorian buyers, car comes with complete roadworthy and engineers certificate for the hole under the battery tray, the front mount and rear strut brace are also engineered with the car. Only reason i have both of these are because i just got defected and had to go through all of that crap.
Car is actually really nice to drive stock and very smooth, i hardly drive the thing anymore i live less than 5kms from work and don’t cruise at all anymore so id like someone else to enjoy it.
So the buyer has two options, buy the car stock or modified, by stock i mean completely bog stock the only modification on the car will be the blue led lights in the speedo cluster, or buy it modified with the following parts list.
Exterior:
- Complete respray by DT panels in Spark Silver
- Genuine GTR front bar with lip
- Genuine GTR bonnet with N1 lip
- Genuine GTR grill
- Genuine Type-M side skirts
- Genuine Type-M rear pods
- Rolled and flared rear guards
- Genuine Nissan weather shields tinted
- N1 head lights with 8000k HIDS
Interior:
- Complete Type-M interior including door trims
- Blue LED cluster lights
- Blitz Racing Meter DC II carbon boost gauge with control unit
Engine/Driveline:
- HKS 2530 turbo with braided lines
- Trust/Greddy Type-M front mount intercooler
- Genuine Trust DD exhaust (only one ive ever seen for an R32)
- Genuine HKS metal intake pipe with HKS mushroom pod
- Rebuilt RB20 gearbox fully reconditioned
- Exedy heavy duty button clutch
- Serviced regularly using all synthetic oils
- Greddy carbon fibre air diffuser
- Bosch 040 fuel pump
Electronics:
- Blitz Spec R dual electronic boost controller
- Apexi Power FC Ap engineering edition (rare to suit RB20)
Suspension/Bracing:
- Tomei 3 point front strut brace
- Cusco rear strut brace
- Cusco castor rods
- Cusco tension rod bar
- Tein Type HE drift coilovers
- R33 front lower control arms (extra track and camber)
Brakes/Wheels:
- R32 GTR/R33 GTS-T brake upgrade with drilled rotors
- WORK VS-KF F: 17x9.5 +26 with a 15mm spacer to clear brakes and R33 lower control arms effectively +6) wearing 215/45/17 Federal RS-R
- WORK VS-KF R: 17x10.5 +/- 0 wearing 235/45/17 Federal SS595
- Black rays wheel nuts HEX
Comes with ALL the stock parts i have all of them, exhaust, turbo, springs, airbox yada yada yada. I also have heaps of parts at home that will come with the car at this price including guards, bonnet, wheels, front bar, front reo bar, headlights, indicators, hicas lock bar, rear GTR sway bar, tyres, theres HEAPS.
I dont want to part this thing out but i think with the current market i will have to so someone please take it off my hands :(
Located Southeast Suburbs Melbourne, please PM any genuine enquiries low ballers ignored, dont like the price push the back button on your browser and keep your opinion to yourself
Cheers,
Kyle
https://www.sau.com.au/forums/topic/351866-1992-nissan-skyline-hcr32-gts-t/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
