has damage to drivers quarter panel/door and to read suspension / linkages, apart from that all is there and needs to be sold
CAT BACK 3 INCH EXHAUST
FRONT MOUNT INTERCOOLER AND PIPING
R33 GTR PASSANGER SEAT
NISMO 300 K/ph DASH CLUSTER
FRONT AND REAR STRUT BRACES
ALPINE IVA-W502E DUAL DIN DVD/SCREEN
BOSS KIT AND SPORTS STEERING WHEEL
GREDDY TURBO TIMER
APEXI POWER FC TO SUIT RB25DET
RB25DET 96,000 K (CAN HEAR RUNNING IF NEED BE
ALL CAR PARTS ARE FOR SALE JUST PM WITH AN OFFER AND WE CAN GO FROM THERE.
CHEERS WES...
Shot gun the front Headlights.. how much? Txt price please on 0422347409
Edited by R33TURBZ WARREN
  • 11 months later...
Hi Wes,
First time post I see, we have not seen you post in the ACT section. Not seen any pics and don't know you (not that that is a crime).
Might help you to sell parts if you post in the ACT section a link here (we don't get many parts locally) and put some some pics up.
Keen to see the damage to the inside door trim drivers side.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
