Ive been looking into yet another brake upgrade recently (this will be my 3rd...) for my s14, and i stumbled across the nissan/akebono calipers that are fitted to 370Z and 370GT premium.
this is the best 'comparison' photo i could find, the other caliper is iirc a brembo (duh) turismo 6 pot.
as you can see, theyre fairly beefy motherf**kers. run a 355x32mm rotor standard.
my question is, will they mount up to an S14? or will i need some sort of adaptor made up? as im not entirely sure what the mounting spacing is for V and Z series cars. nor do i know if rotor offset will be an issue.
if they do bolt straight up, awesome! means a fairly substantial upgrade for under a grand.
cheers in advance, :cheers:
The calipers are ok for a daily rig but not up to some good use, I remember somebody taking those brakes out on the track and on a stock v35/350z it absolutely cooked the seals. Replacement and performance pads and rotors would be hard to come across. And these brakes are very very heavy as well.
Compared to 4/2 pot brembos
Have only heard of one instance where the seals were cooked after track work. The brakes aren't that heavy, the rotors are but I think you can get two-piece rotors for them now (not much more than my 330mm ones anyway). I don't see why performance pads would be hard to come across as they are factory brakes for the 370z/g37, give it time and the project mu, endless, etc will have pads for them if not already.
EDIT: http://www.nissanraceshop.com/product/331115/endless-brake-pads-mx72-front-rear-370z-sport-mx72ep46x
Edited by R3N
Basically the same question got asked a week ago. It has been covered many times in the past.
http://www.skylinesaustralia.com/forums/topic/352049-350z-brembo-breaks-rotoes/
Now since you are asking about the 370Z brakes that is different yet again. You will obviously need a custom caliper mounting bracket to move the caliper outwards to accomododate the larger rotor.
If you Google it there are plenty of threads on it because people always think they can get a cheap brake upgrade simply by stealing another cars brakes. 90% of the time it doesn't work like that and costs nearly just as much as buying a proper brake kit.
Not sure about the rears, but while the akebono fronts are larger and use a larger rotor, the actual pad area is smaller than a r33/r34/350z 4 pot brembo caliper.
That being said the Akebono calipers can be had VERY cheaply if you can get them to fit.
There is a kit offered by CZP for a 300ZX that apparently fits R-chassis and front S-chassis: http://www.conceptzperformance.com/Cart/description.php?II=3310&Car_Type=300&UID=2011020406134892.243.188.8 You can choose a kit with and without stoptech rotors or with no rotors at all, and buy rotors form your local supplier, which makes the kit somewhat cheaper. Browse their site. Good news is that massive 350x20mm rear rotor works with original parking brake (on Z- and R-chassis, that is).
But I dont see the point of adapting those akebonos to Silvia ar Skyline. They are impressively big, yes, but is it a good thing? I personally prefer the caliper to have variety of pad compounds available, have appropriately sized pistons to maintain adequate brake bias, be stiff enough and not to flex under braking, and be as small and light as possible unless it hurts their stiffness. Do akebonos have plenty of different pads easily available for them? Not really. Are they stiff and light? I dunno about stiffness, but they are not particularly light. Are they physically big and do they require big dia. wheels to fit? Yes and yes - more unsprung weight and more expensive tyres.
Plus they have axial mounts, so you'll have to use some dodgy adapters that aren't going to be extra stiff, nor will they be cheap or easy to fabricate.
It's the similar situation to the EVO/Sti brembos discussed on here for a long time: http://http://www.skylinesaustralia.com/forums/topic/203896-evo-brembos-on-a-r32-gtr/.
A substantial upgrade for under a grand will be a Merc or Audi rotor and spaced out factory sumitomo caliper. Same idea, but you won't have to spend money on calipers, just rotors and adapters.
UPDATE:
As for pad size, V36/Z34 pads
are quite a bit bigger than R33/34/Z33 brembo pads
and pads for sumitomo caliper
Yeah, yeah, I know, as laughable as it looks, disregard pic sizes, concentrate on pads sizes in mm shown on every pic. :teehee:
Rear pads on 370z are bigger as well.
Edited by Legionnaire
cheers for the help guys.
not as straight forward as i hoped it would be, ha, isnt that always the way?
no stress though, ill save myself some coin and get the wilall water cooling system instead, that should make the 33 gear im running a hell of a lot more reliable at mallala.
  • 5 months later...
There is a kit offered by CZP for a 300ZX that apparently fits R-chassis and front S-chassis: http://www.conceptzp...34892.243.188.8 You can choose a kit with and without stoptech rotors or with no rotors at all, and buy rotors form your local supplier, which makes the kit somewhat cheaper. Browse their site. Good news is that massive 350x20mm rear rotor works with original parking brake (on Z- and R-chassis, that is).
It's the similar situation to the EVO/Sti brembos discussed on here for a long time: http://http://www.sk...s-on-a-r32-gtr/.
UPDATE:
Great info and thanks for the links!
So, I gather that the Akebono calipers for more for show than actual track'ability. What can someone get if they're looking for a "NISSAN" badge but still great on the track? Basically, I intend to track my '89 GTR.
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
