Need Help With Windows 7 64-Bit And Usb To Serial Communication Problems
Ok
My problem is with FC-Hako and FC Edit to start with. And before I start I'll say I basically bought the FC-Hako to see if I could get it to work on 64-Bit Windows 7, even though it is not officially supported. This was talked about before I ordered it, and if I couldnt get it to work it wasnt the end of the world
Anyway. FC Edit will work with the HAKO on my laptop, however it will after random time intervals apparently lose communication (get a warning "Interface Not Responding") There doesnt seem to be anything obvious that triggers it and I have tried a few things so far to fix it. First up I am running the latest Prolific USB to Serial drivers, have changed the COM port on the USB port I was using from COM 13 to COM 2, played with some of the basic settings for the device and also the FIFO buffers as well. I think lowering the FIFO buffers helped the problem but its hard to say because I could log from the Power FC for longer (it seemed) but it would still drop out
At the moment with the latest drivers, and how everything is now - When it drops out ("Interface Not Responding") I have to close down FC-Edit and restart it to get it to log or read again, sometimes have to disconnect and reconnect the FC-Hako as well. When I had the original drivers on there (the ones I had used a while ago to trial a friends Datalogit, 2007 drivers that where on the datalogit disk) it would drop out and I could sometimes get it to start logging again nearly straight away by starting the log again
Thats basically all I can think of now, basically taking a long shot and seeing if someone on here might have the magical answer for me. Its not an issue as I have access to a 32-bit Windows 7 laptop (which it works flawlessly on) but its not as convinent as using mine.
System specs if it matters.....
Windows 7 - 64 Bit version
4GB Ram
320GB hard drive
Intel Core 2 Duo 2.4GHZ
Thats all I can think of thats relevant lol.....
Thanks
Callan
  • 7 years later...
I had a similar issue before, i resolved it by performing a clean install on the drivers. Ever since never had that error pop up again.
been using fc hako close to 3 years, still running great.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
