alright so i got onto it this morning with perth finally seeing some cooler weather
first up i made a stensil to transfer onto the bumper
used the body line of the bumper for placement on the car
used a drill to cut most of it out, i used a 10mm on the first but used a smaller 5mm on the second side, which was a smarter move
still took a little bit of finessing to get them to fit,
tried to fit without cutting the reo but it cant happen unless u cut the vents, so out came the grinder, and just notched the reo,
now they didnt fit perfect but am very happy with the end result, i just realised i havent taken a photo of the end result, but i will when i put the bumper back on, just waiting for the sickaflex to dry
these are "GT-R" vents made for the curve of the GT-R bumper, the non GTR one is slightly different (bumper i mean) thats prob why you didnt get a "Perfect" fit
they fit GT-Rs fine :)
glad your happy anyway
we have 32/33 ones back in stock now
Yeh mat I no that's why, it's not that noticable but doesn't quite follow the bumpers radius, pics will be up tomorrow morning, sorry fellas, couldn't believe i forgot the end product myself actually
ok sorry guys here are the pics, as i have said im real happy with the way it has turned out,
and som top views of the vents against the front bar, the small gap is minimal, but for those who are in search of perfection, well u can decide
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
