I never thought I'd be selling this car but due to changed circumstances I need something more practical.
1996 series 2
6 months rego
dual airbags
HID head lights
2 tone Interior re-trim with nissan logos
JUN bodykit
Engine Mods:
Power FC ,hand controller, and boost control kit
Data logit and LC-1 wideband oxy sensor
GCG Hi-flow turbo with vg30 rear housing
Splitfire coilpacks
440cc Injectors
Bosch 040 intank
Z32 afm
Adjustable EX cam Gear
3" turbo back exhaust
Apexi pod filter, in perspex box
Front mount IC with custom piping
Gates racing timing belt
UNDERNEATH:
Whiteline adjustable sway bars front and rear
Adjustable rear camber
Hicas lock out bar
A1rm brake pads F&R
INSIDE:
Alpine headunit +six stacker
Pioneer 6x9's
Cadence 6.5in Splits
Cadence amp
Kicker sub
Tinted windows
Short shifter
Blue LED dash LIGHTS
I WILL TAKE PARTS OFF TO MAKE IT CHEAPER
NOW $14500
WILL SWAP FOR A LATER MODEL 4 DOOR FAMILY CAR eg. LIBERTY,IMPREZA
AND CASH EITHER WAY.
I WILL ALSO CONSIDER SWAPPING FOR A TRACTOR WITH FRONT END LOADER.
post-24599-0-09617300-1296125658_thumb.jpgpost-24599-0-67591900-1296125784_thumb.jpgpost-24599-0-31844600-1296125725_thumb.jpgpost-24599-0-41722900-1296125810_thumb.jpgpost-24599-0-64103800-1296125835_thumb.jpgpost-24599-0-89847000-1296125915_thumb.jpg
Edited by Hootchy
Ah if you were not so far from sydney I would be pretty interested, just moved to aussie and wanting to replace my NZ r33
Saw this car on ebay - gl with the sell. In my op even with the mods you might find you have to drop the price again. I bought mine for $7500 AUD in NZ a few years ago and sold it for much the same (actually the rate was not the same back then so more like $8500) - yours is sII though, with nicer interior and more mods. I have noticed less good skylines for sale here in Aussie too, which prob drives the prices up. Good cars. If you can't sell at your current location for current price and are prepared to drop a few grand + bring it closer to sydney, let me know, fewer mods is ok.
Cheers
Duncan
  • Like 2
point taken
$13 000 ono as is
$10 000 with stock turbo , ecu, injectors, afm, coilpacks.
might be able to deliver to sydney for serious buyer
Edited by Hootchy
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
Car is rego'd till mid march 2012.
Dash surround can be painted.
Sorry sold some of the mods already
though it still has
Bosch 040 intank
Hicas lock out bar
A1rm brake pads F&R
HID head lights
JUN bodykit
Pioneer 6x9's
Cadence amp
Kicker sub
Tinted windows
Short shifter
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
