Hey guys,
Selling a lot of parts off my GTR due to going single T04Z turbo and upgrading most other parts.
Used but in excellent condition Blitz Pod Filters and pipes to suit GTR - $150
R34 GTR Turbos Rebuilt with steel exhaust wheels under 15,000kms ago. Minimal shaft play and in excellent condition. Cost $2500 when purchased (have receipt to prove) - $800
New Tomei Poncams Type B - $650
GTR BOVs in good condition. Comes with piping brackets,etc.. - $110
R32 GTR intercooler in excellent condition. No dents kinks, etc... - $120
Twin turbo piping, intercooler piping, standard dump pipes, front pipe, etc... - $offers?
5 factory forged R32 GTR rims with tyres. 4 rims are wrapped with Kumho KU36 tyres which have 80-90% tread left. The spare is wrapped in Bridgestone GIII with 70% tread. The rims are in really good condition. The spare has some light rash but the others are fine.
Rim specs are 16" x 8" +30 and tyres are all 225/50/16.
Looking for $800ono for the 5 rims and tyres. Not bad value considering I paid just under $1000 for the 4 KU36 tyres alone.
Complete front and rear brake setup out of my R32 GTR. Included is 4 brake calipers 70k kms old, 2 front drilled rotors, 2 slotted rear rotors and a set of brake pads to suit with plenty of meat left.
Looking for $500ono.
Standard Coilpacks off R32 GTR that;s done a genuine 70,000kms. Excellent condition. Never missed a beat. $50ono
Cobalt Air/Fuel Ratio meter. $40
Standard Air flow meters off R32 GTR. The joints have been re soldered recently by my cousin who is an electrician - $50
Exhaust manifold with heat shields - $100 ono
R32 GTR custom oil cooler kit. This was a custom made kit made by Tenegah. The oil cooler sits in front of the subframe and has an under tray with scoop that draws air to the oil cooler. It also comes with a Greddy oil filter relocater. It comes with everything required to fit. - $300
Located in Perth but can post at buyer's expense.
PM or contact 0402870429 if interested
Thanks
Edited by Chris32R
Could you please give me more info re the turbos?
Who rebuilt them and with what?
Were they hiflowed or anything?
Are they still ball bearing?
Have you got any dyno graphs so I can see how they went?
Tried to PM
Does the oil cooler come with a thermostat?
Yes it does.
poncams to suit 32 gtr?
Yep, To suit R32 and R33 GTR.
Turbos are on hold atm.
I'm going through messages now.
If you have any questions, please call, SMS or post in this thread because my PM isn't working for some reason.
Thanks
Edited by Chris32R
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
