looks like I voted in the "built engine failure" too early. althou this looks to be tune or fuel or something? only just click over 10k, recent tune to 700awhp HKS 2.8L CP pistons, TO4Z
long story short, noticed engine using oil, even after changing to a thinker oil,
#6 plug oily , #1 white ?? got compression and leakdown tests
compression (psi) 135, 135, 130, 130, 135, 130
Leakdown (%) 8, 6, 5, 5, 6, 10,
also had a look with the scope, can see #6 has some pitting damage from pinging? (detonation? ) the other pistons look ok ( from the top), so looks like at least 1 new piston. not sure whats going on with #1 ? in the leakdown.
anyway this was supposed to be a short story. If I was to pull the motor out, take the head off etc and just drop off the bottom end, to be stripped and rebuilt with new pistons ( lets just say we go for 6 new pistons, not sure what else would need replacing? bearings etc? ) the main Question from all this is, what is a reasonable price to pay for this job ??? assuming everything else is still serviceable .
https://www.sau.com.au/forums/topic/351924-need-new-pistons-etc/
Totally depends on what else you find when it gets pulled apart.
There might be a bit more than just piston dmg due to the detonation.
It could be 2.5k, it could be 4k
yeah i know, can't really say until it comes apart, just chasing ball parks, got a bit of a shock when the first price I got for the above job was $6500+ and that was if they didn't find anything else, ( thats a perth price )
You want to do bearings as well if you are pulling the pistons out due to detonation damage, no doubt they will be roughed up slightly as well.
Also if you can pull the motor out yourself and disassemble it as needed, get someone who knows what they are doing to diagnose the failures/damaged bits then buy the parts yourself and just pay a builder to put it back together you will save a fair bit.
Edited by Rolls
cheers, thats what I'll probably end up doing, try and save some cash and maybe learn a thing or two along the way..
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
