most of the Jap cylinder heads are good from the factory and only need a little clean up
RB heads fit under this umbrella for most people's needs. Rules probably change a fair bit if you're wanting to exceed 500rwhp / 375rwkW.
All the little bits like port matching are great little improvers of flow efficiency on both sides, likewise those bumps in the exhaust ports. The inlet ports are quite large, and given you're talking forced induction there is probably not that much gain from spending wads of time and $$ in that area. Those exhaust ports look to be where the better results are had IMO.
I don't understand the appeal of a mirror finish. All the best jobs I've seen on well built engines have been finished with 120grit on a flapper wheel. Mirror finished can be bad, you are prone to a sticky fuel / air / gunk residue on the inside walls of your intake chamber etc if there is a mirror finish. You need a light abrasion given by a flapper wheel with a grade that isn't too fine in my opinion (Newbie / Novice at best) though I have seen some expensive engine builds, along with backyard builds and most in-between.
If you look closely/read what has been written in this thread, the inlet port you talk about isn't polished but finished in 80grit. Exhaust/combustions chambers have only been polished. Just doing what my tuner has suggested.
:yes:
Think of a golf ball if you don't believe him
See above.
See above.
Which would be fine if it were true. Golf ball dimples are not about drag, they are about lift. Everyone keeps touting the drag myth. In reality, the dimples do in fact grab a thicker boundary layer (as argued by the drag reduction people), but the actual reason that a dimpled golf ball flies further than a non-dimpled golf ball is that the ball is spinning, and the thicker boundary layer causes more lift (the lift results from the back spin). More lift means more flight time and so it goes further.
If you pitch a dimpled golf ball and don't back spin it, then it will go almost exactly the same distance as a non-dimpled, non-spinning ball.
Rough surfaces on inlet ports are a completely different story and not really about the aerodynamics. They are really about providing a surface that does not "wet" the way that a polished surface does when atomised fuel hits it. The increased turbulence and thicker boundary layer around the rough surface do play a part in that.
  • 1 month later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
