Hi All,
Looging to upsize my stock r34gtt to a GT3582r-iw also icluding fmic and 3" exhaust
Can someone give me a quick pros & cons of trbine trim size
check this link -http://www.turbotech.com.au/turboproducts_listing.ews?turboproducts.ewdBrand=1&turboproducts.ewdBrand_Clasification=8
Im in perth..
are these prices ok? any recomendation to go elsewhere for cheaper.
Is this bolt on? I doubt it is.
What else to I need to do just to get it in and running, not intereseted in hi kw just want it in bare minimum and working.
https://www.sau.com.au/forums/topic/352001-turbo-upgrade/
First thing I can point out is the wastegate. An internal wastegate on such a big turbo will yield poor boost control. If I was in your shoes I'd be spending that little bit extra by buying an external wastegate, it'll make a huuge difference to how he car drives and your boost curve will love you for it...
What sort of power are you after?
No this isn't a bolt on option, you'll need to modify your cooler piping to fit the compressor housing, and you'd definitely want an aftermarket dump pipe (3" at least).
I'd recommend Hyperdrive in Malaga, Andrew does great, honest, (relatively) cheap work...
https://www.sau.com.au/forums/topic/352001-turbo-upgrade/#findComment-5645764
If you don't want "hi kw", then that turbo is a terrible choice.
A GT35 is capable of around 370rwkw on a normal day, and not the turbo for a factory motor.
So as with all other threads like this, how about we try a bit of Q&A.
What are your power goals?
What is your budget?
What is the use of the car?
Do you want to rebuild the motor?
What other mods do you have?
https://www.sau.com.au/forums/topic/352001-turbo-upgrade/#findComment-5645769
It all depends on the size you want for the turbine side, AR 1.06 might be a large for a 2.5L engine (it would take a lot longer to spool). You would need bigger injectors to reach the limits of this turbo, and heat may be a problem on the stock internals at 400 -600hp (unless maybe you run e85).
Not sure about the answers to your other questions. I'm assuming that you have an aftermarket ecu, cos you will need it.
Check out gcg, hypergear, etc. Hypergear have a range of bolt on upgrades for RB25DET's http://www.digi-hard...rbocharger.html , http://gcg.com.au/
good luck!
Edited by Shazza24
https://www.sau.com.au/forums/topic/352001-turbo-upgrade/#findComment-5645774
Ok thanks guys yes a general thread would be awesome.
What I did was browse through some dyno graphs and with bb bearing turbo being my preference I thought an ultimate 300rw kw is a good aim.
Ok but not on a stock motor.
So to get going at bare minimum: I'm not interested in any great immediate power gains if any at all just to get the foot in the mod space with the most important bit - in a way doing it in reverse if you like.
So far gt3540 dump pipe and external wastegate and run at 12psi or whatever the injectors can handle. I have apexi neo fuel controller already installed.
https://www.sau.com.au/forums/topic/352001-turbo-upgrade/#findComment-5645814
Well for 300rwkw, a GT35 is the wrong turbo. I told you that not 2 posts above, it is capable of ~370rwkw.
If you really did read the dyno graphs, you would have seen this yourself.
Either way there are plenty of threads on GT3582 (~370rwkw) and GT3076 (~300rwkw).
Please use the search function in future:
"GT3582"
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&do=search&fromMainBar=1
"GT3076"
https://www.sau.com.au/forums/topic/352001-turbo-upgrade/#findComment-5645830
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
    • I got the ARC M079 due to the space constraint.  Been running mint for the last 3 years.  Plazmaman also seems like a really solid choice but not used myself.    Hunt around for a better price but this is what I have - https://www.rhdjapan.com/arc-brazing-intercooler-smic-m079-bnr32.html
