We're talking about 4 piston caliper here, right? If so then it's easy.
P/N is 41121-30P00 for a piston, you obviously need 8 of them per car.
You may want to buy a seal kit for pistons as well. Its
P/N is 41120-30P25, apparently you need only one per car.
P/Ns are identical for any Sumitomo Nissan 4 piston caliper, be it 300ZX, Silvia or Skyline. As for availability, I think you should check it with a dealer.
Edited by Legionnaire
Depending on what genuine charge, the better option is to get Project Mu's caliper rebuild kit. They use alloy pistons, which compared to the standard pistons save about 400grams, which is all unsprung, so handling benefits from the change. I used the PMu caliper rebuild kits in my Impreza rally car (exact same sumitomo calipers as the Skylines) and it was far cheaper to get he Pmu kits (which include the seals etc.) than it was to buy genuine.
The kits to suit are $429 for the front (both calipers, ie 8 pistons and seals), and $265 for the rear (again both calipers).
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
