  • 7 months later...
Don't know what you guys think, but I don't know why the Top Secret style rear difussers just doesn't look very nice (may be aerodynamic or whatever). The Abflug one looks tities.
Abflug is deffinately the way to go for r33's
I finally got mine yesterday after 8 weeks of waiting, but all I can say is that it's worth every cent I payed. The quality is unbelievable, genuine carbon fibre, none of this fiberglass with carbon over lay.
Now I just gota wait to get my car back to put it on
PICS OR BAN. :thumbsup:
I like your taste. I just bought a series 3 front bar for my GTR and have just ordered a set of new TE37s. I like the stock standard, clean, aggressive look as opposed to the street racer theme. Maybe I'm getting old. :rolleyes:
Hmmm this diffuser talk reminds me i purchased one about 6 months ago LOL.
I should go and get it installed. Pretty sure it's Top Secret or similar
Yeah Ash, put it on seeing you've spend the cash. Post up some pics of it on your car.
Kev
  • 5 months later...
  • 3 months later...
cops no, humps not really
My car isnt stupid low, its lowered but not to much. I've bent the brackets coming out of a bad driveway but as long as your careful its not a big deal. If you drive to protect your front bar then its not really much different to protect the back from my experience with it. You're aware its there so you drive a bit more careful
  • 2 months later...
I have Phils old diffuser with N1 GTR pods and its not an issue. They are for GTR's after all
seeing as r34 gtr diffusers are hard to come by, this has given me idea to buy 34 top secret diffuser and cut the middle bit out that folds up and adding fins ? could come out alright and qtr of the price
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
