  • 7 months later...
Don't know what you guys think, but I don't know why the Top Secret style rear difussers just doesn't look very nice (may be aerodynamic or whatever). The Abflug one looks tities.
Abflug is deffinately the way to go for r33's
I finally got mine yesterday after 8 weeks of waiting, but all I can say is that it's worth every cent I payed. The quality is unbelievable, genuine carbon fibre, none of this fiberglass with carbon over lay.
Now I just gota wait to get my car back to put it on
PICS OR BAN. :thumbsup:
I like your taste. I just bought a series 3 front bar for my GTR and have just ordered a set of new TE37s. I like the stock standard, clean, aggressive look as opposed to the street racer theme. Maybe I'm getting old. :rolleyes:
Hmmm this diffuser talk reminds me i purchased one about 6 months ago LOL.
I should go and get it installed. Pretty sure it's Top Secret or similar
Yeah Ash, put it on seeing you've spend the cash. Post up some pics of it on your car.
Kev
  • 5 months later...
  • 3 months later...
cops no, humps not really
My car isnt stupid low, its lowered but not to much. I've bent the brackets coming out of a bad driveway but as long as your careful its not a big deal. If you drive to protect your front bar then its not really much different to protect the back from my experience with it. You're aware its there so you drive a bit more careful
  • 2 months later...
I have Phils old diffuser with N1 GTR pods and its not an issue. They are for GTR's after all
seeing as r34 gtr diffusers are hard to come by, this has given me idea to buy 34 top secret diffuser and cut the middle bit out that folds up and adding fins ? could come out alright and qtr of the price
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
