Hi there guys, so as the title and description state, iv'e tried to replace my pod filter with a carbon fiber closed pod filter, a Monza one. Along with this i also replaced the intake tube with an aluminium 5 piece adjustable one. I put mini breathers on the two hoses that were connected to main air pipe as well. So everything was connected properly as the guy from Autobarn told me to, i kept the air flow sensor and connected that to the adjustable pipe as well, how it was connected previously, but when i tried to start my car it simply kicked over a few times then died out.
I have tried to trouble shoot the problem but iv'e come up with nothing. Iv'e taken off the carbon filter and put the old one on yet to no avail. Iv'e taken off the mini breathers one by one and yet nothing, so now iv'e restored everything to how it was and I am currently waiting for the super glue to dry... i had to cut off a little pipe outlet thingy to connect a mini breather only to realize that i could take off the hose and connect it to the metal connector inside =.=" stupid, yes i know.
So guys, please if anybody has gone through this at all or if they have any input to help me i'd be greatly appreciative... so please help!!
Car type: 1993 Skyline R33 GTS
https://www.sau.com.au/forums/topic/352216-need-help-air-filter-disaster/
some cars i know ie commodores will sometimes not want to start if u put on a pod filter, or they take longer to crank over.
did u take off your AFM/MAF? if u did your car wont start.
put everything back the way it was previous and reset the ecu, see how that goes
The car originally had a Drift cylinder pod filter on it with a makeshift heat shield... the heat shield was scratching the engine bay so thats my reason for wanting to change it. I had the AFM connected when i put everything together and now when I restored everything. How do i reset the ECU though?
"...mini breathers on the two hoses that were connected to main air pipe..."
Aren't the mini breathers supposed to be on the valve cover and the two hoses on the main pipe blocked?  Can you post a photo?  It should be an easy fix if it ran before the change of air filter.
Hey theres guys, sorry for not updating this thread... i sort of forgot haha! Well I did manage to fix this problem, I put everything back together how it was and that worked great so instead of replacing all the pipe work i returned all the parts i bought and bought a K&N cold air intake instead. It is a VERY tight squeeze but hey... it suits the engine bay all nice and black and seems to be working quite well.
All in all I think some advice I can offer to people is to invest in a more expensive product as they work better!! xD
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
