hi everyone just after a pair of good condition factory side skirts to suit an r33
let me know in the post or pm me with details and i'll get back to ya
am located in brisbane 4124.
thanks luke
https://www.sau.com.au/forums/topic/352227-r33-gts-factory-skirts/
  • 1 month later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
