Damn, what a nice series 3 GTR. Great example of a fine R33. If I didn't already have a GTR, I would definitely consider yours. Good luck mate!! Great price too!
I saw this car last week and was amazed. I cannot belive that it still hasn't sold. The car is in mint condion and doesn't have a mark on the interior.The motor and gearbox have the goods and the wheels are awesome.
Guys that live in Sydney - go for a drive to bathurst, buy the car and do a lap of mount pamarma. Trust me you won't be dissapointed!
I thought the car was well under priced. I seriously would have bought it, but decided I'm just getting to old for a modified R33. A forty year old with grey hair in this car - I don't think so >_<
Edited by aus spec 32
steve, u have gone soft mate :)
Now I know why u sold my old gtr back to me, too old to handle the power hehe
I've had my eye on this 33 since the 1st day it appeared on sau BUT I couldn't resist buying my old gtr back, thank you steve! I even spoke to u about this car, just buy it or I think u will regret it.
Seriously though, I would have bought this car even though I haven't seen it, built by crd and its the best colour silver. Don't drop your pants on the price or I will be very disappointed.
Thanks for the kind words guys! Lol never to old for power steve! Was great to meet someone also with the same passion for the GTR and who can also truly appreciate an immaculate example,
No intention of selling it for peanuts as I love the car, but It truly is going to waste just sitting in the shed.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
