Most people may know about this, but some may not read the NSW section.
http://www.skylinesaustralia.com/forums/topic/350755-s-a-u-n-s-w-wakefield-trackday/
I've committed and paid money so if anyone wants to try it out but wants a wing man, I'm willing to assist.
It's a little pricy at $210 for the day but.. for a Saturday and with timing included, it's a good deal. Better then a 3 point fine.
It would be great to see a bunch of ACT SAU's go up.
https://www.sau.com.au/forums/topic/352232-5th-march-sau-wakefield-track-day/
Hah I wouldn't be expecting any track brilliance from me at the start - only overtaking would be on the straight.
Will have to see how I go, the other one is very close to my Thailand trip. (yep poor me :P )
unfortunatly this is my birthday, so despite being a day i should be able to do what i want, like go on a track day and have fun destroying my car but im married, so instead i get to celebrate my birth, oh yay
Edited by swannie
  • 3 weeks later...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
