I'm thinking about going up in the morning for an hour or so, if I wake up in time. I need to be back in Canberra by midday. I can probably give someone a lift from the Southside as I will be exiting through Queanbeyan.
Hope you got some more track time after your problem was sorted. I had a similar problem with my 33 at Wakie one trackday. The bigger the turbo or the more PSI you run on old in-take pipes, then the more likely it is that you will split a hose. Lucky for me mine wasn't too bad. I managed to drive home on it by not putting my foot down...
It looked like a really wicked day for all involved. Made me wish I'd kept the Skyline :( But I knew that would be the case anyway. I'll get another one eventually :thumbsup: Was also good to catch up with a few local SAUer's (past and present!)...
So who won bragging rights until the next one happens?
Yes only missed 1st and 2nd sessions. Bragging rights were mine for the SAU RENEW competition in street class.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
