I picked this car up from fatz early in 06 while on a secondment to Sydney. In hindsight it was (very) rough but having grown bored of my previous 4door hr31 gts this felt like a big step up and it did have a lot of good gear, inc a fairly fresh rb26, 5stud, mechanical diff, coilovers and importantly was engineered. It was great fun on the old pacific hwy!
It went over the pits fairly easily once back in WA and after many hours work it eventually looked like this, changes included the rb25 gearbox, all new ps lines, new rotors, removed a few kg of redundant wiring and the wheels from my old hr31.
In hindsight I should have left it there, it was good fun to drive (~400rwhp), relatively quiet and fully legal. But niggling problems were drivig me nuts, in particular nearly no control over boost with the xr6 turbo, and so it began.
The xr6 turbo was replaced by a regular .82 reared gt35, 6boob manifold and custom 3.5" stainless exhaust. I also made up new ally piping to suit the new 100mm cooler. Not to mention many hours cleaning and a lot of polishing...
Also added a custom 4" ally intake pipe, winged rb26 sump made by a mate and some other bits and pieces before completely stripping the intake side down and re-cad plating everything (massive PITA!)
To be continued...
  • Like 1
https://www.sau.com.au/forums/topic/352234-hr31-coupe-rb26-for-now/
The alternator was rebuilt, a long process after a few parts went missing...
The existing fuel lines were replaced with speedflow teflon braid connected to the original hardlines flared to accept screw on fittings. An Aeromotive fuel reg & HKS rail were also added together with 750cc injectors.
Around this time some new wheels showed up
The factory rb26 loom was in pretty bad shape so the powerfc was ditched for a wire in option. After dealing with endless headaches due to the ecu on my previous hr31 (Link plus) I went with the option I thought least likely to give me grief in the future (so far so good) - so an Autronic SM4, 500r cdi and Mercury coils were ordered.
The factory radiator was replaced with a koyo item with twin spal thermo's. A remote filter block was also added to the existing oil cooler and the lines re-run.
Shortly after it went in for wire, turning over for the first time in 12 odd months on the 18th of January (2008) about 4 hours before a local car show (Motorvation).
Needless to say it copped a beating at Motorvation....
With the hicas/ps removed the rear subframe was moving around a lot on the factory subframe bushes, so solid items were sourced together with a nolathane diff mount.
Before going in for the final tune poncams, individual EGT's and wideband 02 were installed.
EGT's and modified manifold
Poncams and camp cap studs
Aaand EGT's installed
The Mercury coils were finally installed (had been running the std coils with the cdi) and it was tuned to 530rwhp at 1.5/6'ish bar with afr's flat at ~11.0. The hr31 irs wasn't particularly suited to being strapped down on the dyno so wheelspin was a major problem. Managed to destroy two nearly new tyres on the dyno :(
The following weekend I took it down to the hi-tech titles completing only one rolling start pass before breaking both stub axles attempting a launch on the second. The first pass returned an 11.8 at 128mph with a 2.2sec 60ft (rolled of the line) and the nearly new os giken twin plate slipping badly at the top end (the clutch was later sold and to my knowledge is still holding up in a 400+rwhp rb25).
I'd say it went bang a split second after this shot...
One of my favourite photo's of the car from the same day
Given 5 stud stub axles are very rare for these things(coming from z31's) the car sat in the garage for the next 6 months while I waited for billet stub axles & companion flanges out of the US.
Ouch..
Before the new axles arrived I was offered a position which involved moving to Noway to work in our Design office for 12 months - effectively putting the project on hold while I focused on work and did some travel.
Edited by DCIEVE
Some time before heading to the drags it was reversed into by a careless council worker so I took the opportunity to fit a uras kit and a wingless boot. Std 4 stud rear axles were fitted so it could be driven to the paint shop and a few weeks later into storage.
It looked pretty odd with std 4 stud wheels!
Revised catch can (routing blowby to the back of the car)
OS quad plate, pita to fit with the motor in - would have been a lot easier to remove the motor & box together and work on it that way!
Just my luck, the day I flew out the bloody axles arrived....
Roughly 1 month after leaving we returned to Perth for a friends wedding... the plan was to fit the axles, shoot the car for HPI, check the tune and get to the drags again.
Sean at ASG ran it up on his hub dyno, without the slipping clutch and wheelspin the 6boob related boost control issues were even worse, with boost creeping to 1.7bar.
Unfortunately bad weather saw the drags cancelled, but at least the axles were fitted.
Axles fitted
And the rear wheels back on.
The weather meant we weren't able to get any good shots for the article besides a few in the garage..
It was then back into storage for the end of '08 and most of '09.
The idea behind purchasing this thing in the beginning was to have something I could use in local club motorsport events, however somewhere along the line this was forgotten. Fortunately a drive at the Nurburgring while in Europe renewed my focus..
I picked up some weds tc 005's on yahoo, 17*9.5 +30 and only 7.7kg a corner! Massive brake clearance for a 17" wheel as well, this shot is trial fitting them over a mates f50 355mm brembo set-up (he liked them so much he went and bought a set).
They're a bit of a squeeze up front, this is with 255 wide v70's. There will be another few deg of camber when it hits the track so clearance shouldn't be a problem.
Also found some alcons to go on the front, and r34 brembo's for the rear.
And while deciding what to do about the 6boob manifold a FullRace t4 twin scroll manifold popped up that I couldn't say no to...
Cheers Snozzle.
The nice nolathane diff mount gave up the ghost and was replaced by piece of EA which makes for a noisy ride. But at least I don't have to worry about dragging the diff along the ground again!
Trial fitting the full race manifold with a gt35 t4 twin scroll 1.06 housing.
The t4 ts housing was a very tight fit, minimal access to oil & water lines and only a few mm between the comp cover and front wastegate. So the Garrett was sold with the intention of replacing it with an s300sx but then Jeff @ full race advised the efr range was coming soon...
I'm currently gathering the bits for a new engine using an rb30 short motor and the existing head as the 26 isn't in the best shape. After a lot of searching I finally have a clean rb30 crank with original/unmarked journals and a std size block.
Lewis engines are putting together an external oil pump kit, which together with the accusump should make the oiling system pretty reliable. The plan is to run e85 so the hks rail and injectors have been sold and replaced with bosch 1600's and a billet rail. Rounding up the bits collected so far is the ati balancer.
New pintle caps on the bosch injectors so they are direct fit
Block and crank ready for the machinist
OMP seats with Bride FX rails
So I just need to collect a few more parts for the motor before it's sent to the engine builder, and decide on a turbo...
Edited by DCIEVE
Hey Nick its Matt Don (RB HQ)...
Best HR31 ever. Remember seeing it on cruise a few years back and fell in love, and still obsessed with it now!
Keen for drive!
Hey Matt, thanks mate. Hopefully once it's up and going you'll see it out and about a little more.
As for a drive, we'll see...!
I love Tc-005s I have a pair of 17x7s in Charcoal
Picked them up for 50 bucks from a tyre shop that didnt know what they were lol.
and the full race manifold is pure awesome
Yeh they don't seem to be all that well known so they go pretty cheap at auction (which is where these ones came from). 50 bucks is a bargain though!!
Yep the fullrace manifold is a nice piece of work, it's the 'power' version which has since been discontinued (larger runners than the 'response' manifold) - hopefully it works well on the rb30.
  • 4 weeks later...
nice mate! you are a brave man to buy fatz's old 31... lol. :) full credit to keeping it going and tidying the old beast up. I've been in it years ago when fatz first put the XR6 tubz on it with fatz laughing like a giant school girl beside me as he drifted the thing. not the safest feeling in the world!!
it's always been a cool car though and with the new full race set-up and the weds it looks shit hot.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
