Jesus nick I can't believe your building another motor!
Nice, can't wait to see it out and about... Powercruise this year?
The rb26 came with the car so this is the first motor I've built for it(and hoping to keep it that way). Powercruise would be nice but I'm not sure it'l be done by then... starting the understand the meaning of time poor :(
nice mate! you are a brave man to buy fatz's old 31... lol. :) full credit to keeping it going and tidying the old beast up. I've been in it years ago when fatz first put the XR6 tubz on it with fatz laughing like a giant school girl beside me as he drifted the thing. not the safest feeling in the world!!
it's always been a cool car though and with the new full race set-up and the weds it looks shit hot.
Brings back memories of the test drive before I bought it lol.
  • 3 months later...
Bit of an update. Still going backwards (stripping parts from the car) but getting closer to the point where I can start putting it back together.
Sound deadening is next up, then it's off to the fabricator.
Std body wiring loom is weighty, looks like custom is the go.
Picked up a flat wheel - great bit of gear
JE/Nitto pistons, Nitto rods
External oil pump, sump with external pick-up / trap doors etc and drive mandrel for the ati balancer.
Dummied up (not my engine)
Some time before heading to the drags it was reversed into by a careless council worker so I took the opportunity to fit a uras kit and a wingless boot. Std 4 stud rear axles were fitted so it could be driven to the paint shop and a few weeks later into storage.
It looked pretty odd with std 4 stud wheels!
Revised catch can (routing blowby to the back of the car)
OS quad plate, pita to fit with the motor in - would have been a lot easier to remove the motor & box together and work on it that way!
Just my luck, the day I flew out the bloody axles arrived....
Roughly 1 month after leaving we returned to Perth for a friends wedding... the plan was to fit the axles, shoot the car for HPI, check the tune and get to the drags again.
Sean at ASG ran it up on his hub dyno, without the slipping clutch and wheelspin the 6boob related boost control issues were even worse, with boost creeping to 1.7bar.
Unfortunately bad weather saw the drags cancelled, but at least the axles were fitted.
Axles fitted
And the rear wheels back on.
The weather meant we weren't able to get any good shots for the article besides a few in the garage..
It was then back into storage for the end of '08 and most of '09.
What Wheels Are they Mate and where did you pick em up from?
  • 5 weeks later...
Not really much in the way of interesting updates. I've stripped all the sound deadening, hopefully picked up a fresh head with some larger cams, springs, retainers (more on this when it arrives) and the new turbo finally arrived. Geoff at fullrace talked me into going larger than I had originally planned, together with inconel studs etc.
Motivation...
Re-tapped the manifold M10 x 1.5 for the inconel studs, quite the pita with very shallow tapped holes. Getting just on three turns on the shallowest of them which is border-line ok.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
