This is the cleanest build on the whole forum. Every time I see your build Nick I want an R31...
Cant wait to see this monster finished! Its going to be awesome :D
Thanks mate :)
on the road yet nic?
Wiring guy has been making pretty good progress but unfortunately tore a ligament in his foot last week. The car is quite literally ready to drive other than some wiring and catch cans which I'll do once running to avoid another trip on the tow truck. What he has done so far looks pretty good though.
Electrical battery isolator replacing the mechanical switch
E75F8DF2-6449-496B-96A0-C670A83CC796_zps
Deutsch connectors everywhere
B7289D15-5C04-4FBC-96E2-E1A0B5571804_zps
Unfortunately didn't get a photo of the engine loom before it went in but it's rather nice!
Hey just out of curiosity mate, what clearance does the Ross trigger kit say to spec the sensing gap between tooth and sensor? 0.040" or thereabouts? Do they just supply shims or something to pack the sensor down or up to get the proper clearance so it gets a good reading?
The instructions recommend between 1 and 2mm (roughly 0.04-0.08"), they supply a few extra washers to adjust the distance. There isn't any means to adjust the cam trigger that I can see but we did measure it to make sure. Are you guys using the same hall effect sensor?
Edited by DCIEVE
If it uses Honeywell 1GT101 DC units then yes we are. We aim for 0.040" as that seems to be the ideal point for accurate reading.
Sooooo when will this thing be rolling under its own power?
  • 2 months later...
Exactly my thoughts.
Took me a couple weeks to read all 10 pages, but it was well worth it.
Very nice mate.
This thread and build is just crazy and pure inspiration :D one quick question dude what is the thread pitch and size of the hose end that goe sin the block for the heater matrix feed? youve used a earls type fitting and this is exactly what i would like to do but i cant find the size anywhere lol
Picture of what i mean:
77908917-C54A-4B75-B5A5-D0BE51D22D49-711
Very nice mate.
...epic!
Thanks guys!
Thanks mate. The rear fitting is 3/4" BSPT (same as the turbo drain) whereas the front had to be tapped 1/2" BSPP (can't recall if I used a parallel or tapered thread fitting though). Credit for this info to r33_racer, a very knowledgeable fellow!
I'll have to update this thread soon..
thankyou very much, and as i said before it has motivated me to keep on doing mine lol, i presume that thread size will be the same on a rb20 / 25 / 26 as i have the rb25 in my s13
Glad I could help... motivation is tough to maintain, especially after a few years in the build.
So I've been keeping pretty busy on this thing, mainly acting like a TA to lumpy (my wiring guy) who casually suggests a couple things I should do/change/improve (in addition to plugging away at the body loom) each time he comes by. Given his full time job is supporting a number of local race cars I try to listen as much as possible... but it does mean the job keeps growing.
Anyway I'll bring this up to date over a couple of posts in the next few days.
After much procrastination I settled on an air oil separator and catch can configuration, started out like this
3CFA0AEE-A9FD-477E-BC7B-35830081AAB0_zps
And after a day with Brad Stacy I had these
5054DE13-2B07-422B-BE56-1CB7255E6EB7_zps
Made some new switch panels and had some stickers made
D7A04A28-1DC5-4E7A-B12B-AD13183B12F4_zps
Relay bases and breakers mounted up. This will sit behind the glovebox with the ecu/cdi on a separate panel in the foot area with the innovate gear hidden underneath.
1458ABA7-194A-469F-A48C-D582585F939E_zps
Coming along! Busbar has been added here.
07AB3DBE-41F1-451D-8D46-0814B51BFA93_zps
Bit of a glimpse into the level of detail lumpy is going to. The connection between the chassis and door.
69C26933-8B04-4297-A82E-148161776E42_zps
External isolator button, we're building a cartek style isolator system minus the massive price tag.
02FE21EF-4B52-4114-AD49-4B8A61BF3189_zps
And Martin from Unzipped Composites has been making me number of bit's and pieces over the past couple of weeks. Have to say great service and a top bloke to boot.
1AF543B5-2C09-4C76-BEAE-3603A2A2BD41_zps
  • Like 1
Lumpy knows his stuff.. Very switched on fella. I haven't spoken to him in years now. He is a great bloke! You are lucky to have someone like him local!
But I'm happy you are making some progress mate! Loving it.
Dammit it took me so long to find this thread! Haha. I had forgotten it was a motorsport build, I was sitting in the normal builds section waiting for you to update :glare:
Lovin' the plug in the signature by the way Nick ;) Thanks mate :thumbsup: Glad those bits came out well. Going to look good when I finish off this cooling panel. Looking at sometime next week I'd say, if I can get my garage warm enough for the resin to cure :down:
Thanks Michael :)
who made the stickers mate?
Need some for my build and they look the best by far that ive seen!
These guys made them up for me (http://www.pgc.com.au/), reasonably good service but a $70 minimum charge. I'm sure you could find a similar shop local to you? Otherwise I need a few more made up so welcome to piggy back an order and spread out that minimum charge!
No worries Martin, looking forward to seeing it! In the mean time some more of your handy work below!
For mounting buttons on the steering wheel
CB3DC024-1CF1-4C5E-9D1E-817C2BDD97F5_zps
And blanking the hole left by the cluster
4A4FA3F6-A701-4CF4-A880-5C69B2A0D64F_zps
Came up pretty well with the buttons installed
355A527D-9CEF-46D8-BB97-21EA888B97C2_zps
And a mount for the GPS receiver
DB602D80-AD2F-4722-8C86-9D26961395AE_zps
I guess we can tell where this is heading! Picked up a dash and logger :)
F171B9CC-077F-4D09-8AD4-DE22251A4068_zps
Mounting it up with some neat brackets made up for me by Brad Stacy.. making almost weekly trips up to his place at the moment.
6F4174CD-C725-4D15-A427-04AE01784711_zps
EFB9D890-46C6-4455-85F9-62A6ED0A9752_zps
  • Like 1
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
