Jesus nick I can't believe your building another motor!
Nice, can't wait to see it out and about... Powercruise this year?
The rb26 came with the car so this is the first motor I've built for it(and hoping to keep it that way). Powercruise would be nice but I'm not sure it'l be done by then... starting the understand the meaning of time poor :(
nice mate! you are a brave man to buy fatz's old 31... lol. :) full credit to keeping it going and tidying the old beast up. I've been in it years ago when fatz first put the XR6 tubz on it with fatz laughing like a giant school girl beside me as he drifted the thing. not the safest feeling in the world!!
it's always been a cool car though and with the new full race set-up and the weds it looks shit hot.
Brings back memories of the test drive before I bought it lol.
  • 3 months later...
Bit of an update. Still going backwards (stripping parts from the car) but getting closer to the point where I can start putting it back together.
Sound deadening is next up, then it's off to the fabricator.
Std body wiring loom is weighty, looks like custom is the go.
Picked up a flat wheel - great bit of gear
JE/Nitto pistons, Nitto rods
External oil pump, sump with external pick-up / trap doors etc and drive mandrel for the ati balancer.
Dummied up (not my engine)
Some time before heading to the drags it was reversed into by a careless council worker so I took the opportunity to fit a uras kit and a wingless boot. Std 4 stud rear axles were fitted so it could be driven to the paint shop and a few weeks later into storage.
It looked pretty odd with std 4 stud wheels!
Revised catch can (routing blowby to the back of the car)
OS quad plate, pita to fit with the motor in - would have been a lot easier to remove the motor & box together and work on it that way!
Just my luck, the day I flew out the bloody axles arrived....
Roughly 1 month after leaving we returned to Perth for a friends wedding... the plan was to fit the axles, shoot the car for HPI, check the tune and get to the drags again.
Sean at ASG ran it up on his hub dyno, without the slipping clutch and wheelspin the 6boob related boost control issues were even worse, with boost creeping to 1.7bar.
Unfortunately bad weather saw the drags cancelled, but at least the axles were fitted.
Axles fitted
And the rear wheels back on.
The weather meant we weren't able to get any good shots for the article besides a few in the garage..
It was then back into storage for the end of '08 and most of '09.
What Wheels Are they Mate and where did you pick em up from?
  • 5 weeks later...
Not really much in the way of interesting updates. I've stripped all the sound deadening, hopefully picked up a fresh head with some larger cams, springs, retainers (more on this when it arrives) and the new turbo finally arrived. Geoff at fullrace talked me into going larger than I had originally planned, together with inconel studs etc.
Motivation...
Re-tapped the manifold M10 x 1.5 for the inconel studs, quite the pita with very shallow tapped holes. Getting just on three turns on the shallowest of them which is border-line ok.
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
