Thanks gents - chipping away at it slowly!
That is a nice tight fit. Looks awesome sitting in there though. I have a 31 sitting next my 32 at home will have to take some measurements the fullrace mani is absolute porn.
The mani is very nice but the finnishing in a few area's isn't to the standard I'd expect considering the asking price. Glad I got mine cheap!
Trial fit of the fuel cell all done, the hole saw packed it in so I had to resort to the slow method (lots of small holes followed by a file!). Good times :P
Cardboard is a template which will be made in steel to cover the old fuel tank access hole.
Edited by DCIEVE
^ thats something i need to do :)
had a look through your thread but i couldn’t see if you where planning on doing some circuit racing. if so, might the cell be in a bit of a dangerous spot or are you going to put some protection around it?
+ where did you get the diff mount from?
great build man :thumbsup:
Cheers James. Yeh the plan is club level stuff but keeping the rego while I don't have space for a trailer and dedicated tow car.
Not sure about the cell location being an issue, I can't really see any difference which side of the floor it sits on from a rear impact point of view (other than fuel spilling on the ground rather than inside the boot if it were to split). I certainly think it's better than mounting it part way through the floor like most people have to do due to the spare tyre well (risk of slicing it in half in a rear hit). It will be covered on the underside if that's what you mean?
Edited by DCIEVE
Brake master, clutch master & slave rebuilt plus some braided brake & clutch lines. Just need to give the booster a sand and coat of paint. Also grabbed some adjustable LCA's - I think originally godspeed but the welds have been ground back and professionally re-welded, they've also been machined to take off the shelf SKF bearings rather than the chinese bearings they came with.
Rebuilt both wastegates with new diaphragms/springs etc and set them up with shortened speedflow fittings (without cutting them down they limited valve travel).
Time to make some intercooler pipes and find someone to do the wastegate plumbing and new dump pipe.
Nice work Nick, got a rough ETA?
Hopefully in the first quarter next year but we will see. I still need to find someone to build the engine, and that's assuming the new head hasn't been lost in transit somewhere :(
  • 1 month later...
So I made good use of the long weekend, progress! But sadly still no head some 4 months later :angry:
Rebuilt brake & clutch masters fitted
Dummied up the flares
Lower rad hose adaptor for the rad breather tank from garage7.
Mocked up the new oil filter location
Found homes for the rad breather tank, accusump and fpr.... the accumulator is friggin enormous! Also fitted up the plenum so it's ready for IC piping to be made.
Getting closer! Shame it's not my engine :P
And put the seats back in so we can fabricate a hardness bar
Time for the fab work and hopefully some wiring.
From fatz stockpile of carbon bits ;)
The diff mount was from z31parts but it failed in fairly dramatic fashion so I wouldn't recommend one. It was replaced with a solid mount..which reminds me I need to find solid alloy subframe bushes to replace the nolathane ones which allow the subframe to move too much.
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
