No worries Harry, I might wander down to one of the jap wreckers in the next week or so and have a look.
Nick, long shot but possibly call Dick's cv's. Really old guy from mandurah that drives around, visits Bunbury every 2nd tues, he might head your way every now and then and may be able to help
Thanks for the suggestion Corey - I'll give him a call.
Started bending up the fuel lines, only the feed line shown here while the return line coil is on it's way from the guys at garage7.
Pump to filter fuel line and pressure sensor, just need to plumb the filter to the bulkhead and from there to the above 1/2" feed line. Baby steps..!
Does anyone have any engine builder recommendations for the Perth area??
  • 2 months later...
It's been a while since I updated this, it's still a way off running but there has been a fair bit happening. It's also in the current issue of Zoom (181) in it's previous guise...and by previous I mean 3 years ago :P
3an vac line to the fpr in teflon braid
Completed all the WG vacuum lines with 4an teflon brain, mostly covered in firesleeve where it runs close to the exhaust.
DEi turbo beanie
Collecting fittings for the oil lines - that's nomex/kevlar braid, a lot lighter than steel braid
New oil cooler, plumbed in with the nomex line and more speedflow
The tee which runs to the accusump and the one way valve. There is also a pressure sensor fitting on the adapter block.
Bulkhead fitting (line runs to the accusump) and cf blanking plate where the heater hoses used to run.
Running line to the accusump which now lives in the boot (cut to length but the fittings aren't put together here). The ball valve is in easy reach.
Bulkhead fitting for the 8an fuel feed line sitting in a cf blank (filling an old hole).
It's almost rolling again now as well...
Edited by DCIEVE
Thanks Steve.
And some more
Subframe painted up waiting for the ally bushes to be pressed in.
Adjustable (toe & camber) trailing arms
All the front suspension parts have been installed so it's ready to roll once the rear end go's back in.
Rebuilt rear drive-shafts - modified so they work with the non hr cusco 2-way.
Any progress on the engine build Nick?
Not as yet, will have to bite the bullet and go with someone soon. Visited one builder recently who pulled out a broken rb30 crank which has me thinking about nitto cranks now..
Nic awesome work mate
This car has a rich history of abuse
Flashback From 2004
I have a few strong burnout photo's from your ownership on the HD somewhere. Not that much has changed!
Edited by DCIEVE
'Outer Control' did the boots etc - very helpful bunch of guys. No luck with replacement parts so we had to rebuild used gear. Fatz helped out with a set of a car he was wrecking.\
Pressed in the subframe bushes, all ready to go back in and get the car rolling again.
oh, this is *that* car....it has a rich motorsport heritage.
Looks like you've done a great job with it, hope to see it on a track soon
Thanks Duncan, proof will be in the driving. Hopefully soon!
Nice work Nick,
The car is coming along well...
Full credit to you at how neat everything is and the quality of the work, makes me want to pull my finger out and neaten mine up...
mine is nowhere near the standard of this build.
Cheers Andrew!
Christmas was a rare opportunity to get some uninterrupted time in the garage so I was able to get a few things done. Getting some motivation back lately.
Undercar hardlines complete. 1/2" feed and 3/8" return.
Reassembled the rear end with the adjustable trailing arms and all new bushes etc
With the rear end back in the car it was time to measure up and make a new solid diff mount. The one pictured below was quickly thrown together after the z31parts item failed leaving the car stranded with it's diff on the ground at motorvation a few years back.
That mount was pretty rough so a friend helped put together a replacement. Putting it on the mill was probably overkill but it was there and we had holidays to kill :P
Trial fit
...and painted
I've also made a start on the flare fit-up - hopefully by the end of the weekend the guards will be cut.
Rear
Front
The rear is quite a bit bigger than the front in profile
Also fitted up the standard rear bumper and garnish I had painted ages ago.
Tentative new home for the accusump - will need a cover in this location but shouldn't be too hard to knock up.
Flares look amazing. It's a shame you cant run some wide Wats on her due to the brakes.
What is the smallest wheel size you can run and still clear the front brakes?
Ditch the rest of the kit and go R31 House lips?
Edited by masTers
First preference was 1 piece 17's (or 18's depending on brake clearance i.e. rpf1's) given they're about as light as you can buy but they don't come wide enough, or with low enough offsets for the rear. Which leaves me looking for something 3pce and 18" with custom widths/offsets... bbs e88 are on the wish list but well outside budget so some 3 pce Works might be the way to go.
As mentioned earlier, trying not to waste time on things that don't get it running or aren't going to improve reliability or performance so the kit stays :)
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
