Considering selling my 32 GTR, I just have not had the time to spend on or in the car and am considering going back to one car...
Heres some details:
Motor
Receipts from previous owner for 2 rebuilds...appears first one died...
Current engine rebuilt by Serge of John French Motors in QLD approx 10000kms on this build.
33 Block and Crank
Forged pistons
Mild head porting
Competition Valve Seats
ARP Head and Main studs + Rod Bolts
Tomei Gasket kit
-7 Turbos
Tomei Cam gears
Apexi PFC with Boost control kit
SX Fuel pressure Reg
Brand new HKS pods and custom piping, all neatly mounted, nice and secure
Ceramic coated split dumps into full system including big metal cat, exhaust is very quiet
Recently fitted Tomei Type B cams (yet to be retuned)
All receipts for engine build available totalling some $10k.
Will also include a set of brand new Siemens 740cc Injectors
Just had engine covers painted candy red and inlet manifold/twin turbo pipe Ceramic coated...$$$
Gearbox/Clutch
Single plate cushion button with Billet Flywheel
C's Short Shifter
Wheels/Tires
18x10 +12F +11R Work GT-Ps in Diamond finish, mint condition, just bought these through Importmonster and was amazed at the condition, no rash
Bridgestone Potenza 265/35/18s
Suspension
Brand new adjustable Selby front swaybar.
Cusco front strut brace
Rear strut brace
Currently sitting on stock shocks/springs for roadworthy inspection, will come with set of Koni Yellow Height/Damper adjustable shocks and Whiteline lowered springs
Original interior is very clean, original steering wheel restitched in black leather with red stitching. Car was resprayed (beside the bonnet) a few years ago so body is nice and straight and no rust.
For those interested -
I bought this car from QLD and it was pretty untidy in general when purchased...ive spent ALOT of time and money already getting it to where it is, genuine badges etc arent cheap! The car is currently out of reg and ive got it to a point where its ready for its inspection, its running stock ECU, stock Suspension, high mount stop light fitted, all the bits required to pass. Im not going to go into too much detail but long story short, Transport SA didnt recognise the QLD Mod Plate used when it was originally Complianced way back when so it requires an inspection here in SA for registration.
I will include everything required to return the car to its previous state, it is not alot of work.
Also have a polished catch can (over the cam cover style) and whiteline front camber kit to go with the car.
Some pics, call if genuinely interested.
With a little work refitting a few parts and a tune it will make low 300rwkw on 18ish psi. Was already making 270rwkw on 14psi before cams were fitted.
Sits a little mexican at stock ride height but should tuck in nicely once lowered....
With front jacked up, gives some idea how rear will sit once lowered...
$23.5k
May also consider swaps for something of interest, tough S15, not sure what else would grab me...EVO, Supra, old school SR Datto?
0412 957 615
Edited by NSNPWR
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/
Hey mate, yes its an '89 and thats cool, can understand that it wont appeal to everyone in its current form but really the only stock parts are the ECU and Springs/Struts.
ECU is a simple swap back to the PFC, refitting the PFC Boost Controller is a piece of piss (2 vac lines) and the Struts are easy as to swap over in these things.
Cheers for your interest.
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5648314
Few other things I forgot car has fitted...
Tomei Fuel Pump
16" electric fan - removed clutch fan
Immobiliser
Sony 50x4 Head unit
Redline Gearbox oil
Motor also had all pulleys/tensioners/belts replaced when rebuilt
Edited by NSNPWR
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5649507
Add to list:
N1 Oil and Water pumps bought new from Nissan, fitted with last build.
Climate Air works perfect, has had various sensors replaced at some point.
No cracks in dash, fitted new centre dash vent, all dash lights working, recon headlight switch.
AFMs resoldered.
Edited by NSNPWR
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5650036
Add to list of mods:
Oil filter relocation kit.
New Radiator at same time motor was built
Windage tray also fitted at time of build, cradle drilled/counter sunk and tapped to accommodate.
Will also include:
Tomei HICAS lock kit, new in box (bypasses HICAS light as well)
GREDDY clear timing cover, new in the box
New set of front Street Fighter brake pads (still meat left on the ones fitted now)
Stock 32 GTR Airbox in excellent condition
Edited by NSNPWR
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5652991
  • 1 month later...
Shame it's not in the right state, would have a potential buyer if it were in NSW. :(
Could be interested mate, but if I'm honest, having bits of stock parts fitted puts me off..
Is this a 1989 then? - Judging by lack of side indicators?
I was under the impression all Japanese BNR32's came without side indicators? (unless they were put on during compliance)
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5716293
All R32 GTR's except the AUS spec ones came without side indicators.
It was just a compliance thing that they were put on and some places / states they were not required.
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5716813
89 Ones didn't require a compliance plate - no indicators.
Edited by Ten Four
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5717033
  • 3 weeks later...
Cheers mate...Now riding on Koni Yellows, fresh 20percent tint just done 2 weeks ago, centre muffler removed...sounds tough, getting a bit of use past few weeks, no issues. As for side indicators, 89s didn't require them, inspector did mention it needed them to pass but then I think he realized what year it was : )
Edited by NSNPWR
https://www.sau.com.au/forums/topic/352241-eoi-r32-gtr/#findComment-5742384
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
