hi am after help with installing my 26/30 setup.
when i bought the engine it only had the plenum fitted, so since getting it i've been piecing all the little bits together, i'm slightly unsure on a couple of pieces as most people that have done the conversion already had an rb26 and dont need to gather up the parts, as so they are not mentioned in their builds.
do i have to use the steel water/vacuum tube that runs alongside the block to connect heater hoses and to the plenum etc, just wondering how other people have done it as their are not many pictures or info on this when using single turbo, without this there are a few hoses that have no where to go and i would like to keep the heater for road use.
if i dont need it which hoses can i block off and which hoses can i connect to each other to not interrupt flow?
i am also curious on the aac to booster pipes, do i need to use these or can i connect the brake booster to somewhere else on the plenum and block off the back of the aac?
any information would be much appreciated as i'm almost finished and so badly want to drive the car again
any help appreciated, thanks luke
https://www.sau.com.au/forums/topic/352321-2630-heater-hoses/
Not sure on the Options of the brake boost but mine is connected as factory. Regards the metal pipe you mentioned. On my build I cut al the vac lines of and kept the main water one IIRC. I might have a picture somewhere. I will look tonight. I think there is a spout you can block and also on the RB30 block there is a little spout on the rear water pipe into the block that can be blocked. I will try and find pictures to confirm for you.
Lee
Not sure if this is correct but it worked well for me.
Left side of vacuum sensor (under injector manifold) to vacuum side of throttle bodies (one of the pipes coming down). Other side of vacuum sensor to plenum.
Other pipe coming down to brake booster. Block off the rest of plenum nipples and use top small nipples on manifold for boost sensors.
I made up my own heater pipes, one from front of block at thermo housing to heater then heater to the last nipple of block (left in picture behind small lines). I had an external oil cooler setup not like your stock water one but you could have the return heater line going to your oil filter/cooler then from it to block.
Not sure if the small lines are for turbo but if they dont plum into the blocks oil or water then get rid of them and use bigger lines from other side of block (may need to be drilled and tapped but worth it).
My idea is to keep it flowing and simple. Block diagrams can help you see how water and oil moves through the RB30. I remember that it looks like pluming for the turbo water in from one spot and out at another wouldnt flow but it does due to the suction of water passing by the connection point.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
