Cyclone Yasi
PM-R33
 Share
Yeh, worst part is the uninsured skyline in my drive way. If it get wrecked im going to rebuild it and get Yasi number plates :thumbsup:
thats the spirit mate. Do all you can to protect you and yours then just spit in its face and say bring it bitch,
Good luck up there guys, We're thinking of you.
  • Nope 1
Cheers mate, my biggest problem at the moment will be the beer supply after tomorrow..
Is anyone else a little worried with what the tail of the cyclone is doing?
Im no expert in weather but it seems to be nearly starting to swirl itself.....
Infrared Loop
Yep noticed it, and someone brought it up in one of the Bligh or gillard conferences but they quickly said no
Its getting windier here now, just pulled off my outside ceiling fan cos it was getting a fair wobble! Power is still on here to but i reckon it'll go off just as i start cooking dinner!
 Share
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
