Cyclone Yasi
PM-R33
 Share
God damnit the thing is coming back towards us again!
Ohh this aint going to be good...
wish u guys up there all the best. Take care and we will see you all on the other side.
wind is slowly picking up here (no where near cyclonic but), been raining on and off all morning. My iPhone weather app says "Squally rain, damaging winds" as todays forcast,
Squally rain...... Who says that?
Its pretty much over willis island right now. how the folks there didn't stay (though the radar is still working, so it must be pretty dam strong) http://www.bom.gov.a...loop.shtml#skip
Willis Island automatic weather station has called it a day, they usually pack it in at around 90 knots.
Used to have an underground concrete bunker but it was removed, think I'd prefer that over the new stuff built there.
Be interested to see how much is still standing.
Have a mate in South Townsville off Boundary Street tell me they had surge waters coming through the street at 10 am today. They packed up and got out. Parents place in Idalia is sandbagged the sh!t up, so hopefully should be alright.
All servos are closed and I heard the highway to Bowen is closed? Then I saw plenty of people heading west towards the Towers??? I don't know why you would bother, nothing there is rated to any form of cyclone. I'm praying it doesn't swing south anymore but there is nothing more to do than sit tight and wait this out. Goodluck dudes!
They will head for the towers because it will be the best way to go south, I would go as far as hughenden if I were there.
And here it is! Winds are really starting to pick up. Shit is starting to bang around the house. I'm worried my double garage roller door is going to blow inwards!
EDIT: That should do lol.
Its just starting to get breazy here (kirwan townsville). Not hugely worried though i've got plenty of beer and a salami and the car is safely in the carport.
Looking at the tracking map even Mt Isa is going to get some! thats one f*ck off big storm to get that far!
Edited by R33shaun
Phil, youve done the matress thing with your car, probably the best and only thing you can do.
Live Webcam, Townsville CBD
Magnetic Island hidden by rain now, would be pretty rough over there, did they evac everyone off there?
My Weather app, current data (wind speed):
Mackay - 30km/h
Townsville - 46km/h
Cairns- 11km/h
Bowen 46km/h
So up north of the cyclone is defenitly experiencing "the calm before the storm"
 Share
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
