The guy I got the turbo from is willing to buy me a new shaft. I just need to know the part number for the shaft. Does anyone have any idea?
If its gonna cost me another $200 - $300 to fix, ill pay that. I cant just throw $800 away(thats what it cost me). At the time we both had no idea the wheel was damaged.
Ive been in and driven my mates r33 rb25 with gt3082 .63 on 19psi and its nothing short of fkn wicked.. pulls hard cooks tyres .. 290rwkw. Enough said.
Is it internal or externally gated? Im guessing its external? You'd have a pretty hard time contolling boost with such a tight rear hsng and piddly internal gate.
I thought you already had an external gate ready to go? Whats sort of gate is it? Get someone to weld a flange to your stock manifold as pictured on the page previous...it will work if the gate is big enough...contrary to what Mr High Horse would have you believe, seems there are plenty of people out there that have made this turbo work, including a mate of mine who had the 0.63I/W on his series RB25, made 280rwkw on 18psi, only problem was he couldnt keep boost below 18-20psi...hence my post above...go the external if youre staying with the 0.63 hsng.
Ive got a 44mm tial. The guy I bought the turbo from is helping me organise a brand new one! He also said he will get me one with a .82 rear if I like. I will go with this option and keep it internal. With a bigger housing, the gate should be able to flow enough through to keep boost constant. If not, Ill get the actuator rod locked rather than the flap welded and have a secondary manifold with a WG flange as suggested previously.
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
