hey people, done a quick search but couldnt really find anything,
is anyone using the cooling pro r33 ally radiator in there s1??
i know i will have to use an auto cooler thats not a drama but really want peoples opinion on fitment, size and if the shroud actually fits!
thanks people!!
https://www.sau.com.au/forums/topic/352379-radiator/
You need a AUTO specific rad with the bottom tank setup for auto trans fluid. That bottom tank isnt their to "cool" the fluid its their to get it up to temp and keep it at as much of a consistent temp as possible..
I have heard that before. So why have a tranny cooler??? >_<
https://www.sau.com.au/forums/topic/352379-radiator/#findComment-5651040
Not trying to sound smart, but there seems to be a bit of confusion surrounding trans coolers and their use; hopefully this helps.
The thing in the bottom tank is a heat EXCHANGER; not specifically a cooler or heater.
If the water is hotter than the trans fluid; heat will be transferred to the fluid, if the fluid is hotter than the water; heat will be transferred to the water.
Under duress, the trans transfers a decent amount heat into the trans fluid, it can easily go over 100 deg in the right conditions.
The heat exchanger in the radiator is usually nothing more than a simple copper or aluminium tank, no fins for extra surface area. They are not particularly efficient.
So in extreme conditions with high water temp, using a dedicated trans cooler is much more effective at stripping that heat out of the fluid, making life easier for the gearbox.
Also, ambient temp is always going to be lower than the temp of the water in the cooling system.
A side benefit is reduced load on the cooling system.
Running the fluid throught the radiator mounted exchanger, in addition to an external cooler just ensures the trans fluid will be around the same temp as the radiator water, not ambient temp in cold conditions; as Pipster & Kidafa have said.
Edited by Daleo
https://www.sau.com.au/forums/topic/352379-radiator/#findComment-5651186
i dont understand either, the auto-trans specialists up the road from my work say built in radiator trans coolers are rubbish. and then why do people fit large external trans coolers for "towing/extreme condition/high perfomance applications" ? also read an article in a 4X4 mag that said the higher your auto fluid temps the shorter your auto trans life and it had a graph with "auto fluid temp" over 'hours of life".
all autos will be sluggish when cold regardless of 'heated' or external cooler. My x-trail i just sold (my07) had a built in cooler and i fitted an external cooler and it drove the same, had long drawn out gear changes for the first 5 mins of driving til the trans fluid got up to temp, the external cooler didnt take any longer or shorter to heat up than the built in one.
personally i would run the cooling pro manual stagea 3 core radiator, a moderate size external tranny cooler and a top quality trans fluid.
also as chuckie mentioned, use the search function and there is a billion radiator and tranny cooler threads
https://www.sau.com.au/forums/topic/352379-radiator/#findComment-5651192
if i did it again, i'd get one of the asi radiators from ebay
same quality as cooling pro (ok for china) but about $100 cheaper
oh, and i read about the auto heat exchanger, you only need it in cool temps or your fluid will not warm up if you have an external cooler
https://www.sau.com.au/forums/topic/352379-radiator/#findComment-5651263
yeh like if you live -20 degree conditions in the middle of the day you would need it, i believe now some german cars have electric elements in the engine oil sump to heat the oil so its easier to crank when cold?
In some sub arctic countries, rather than heat a garage, they do exactly this, just need to remember to plug your car into the power point before going to bed.
https://www.sau.com.au/forums/topic/352379-radiator/#findComment-5652579
my aunt in canada has had that for years
also means that the heater blows hot air as soon as it turns on
https://www.sau.com.au/forums/topic/352379-radiator/#findComment-5652862
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
