In the boot of my r32 gtr there is this little box with Kansai service on it and a green button when pushed in it lights up.
I have only driven the car with it off, and only discovered it after i had spun a bearing. so i cant drive the car to see if it does anything.
I have googled it and it only comes up with kansai tuning shop.
Anybody know what it is or what it does?
Thanks!
https://www.sau.com.au/forums/topic/352401-anyone-know-what-this-is/
Thanks!
Is it under the parcel shelf between your rear speakers?
holy crap..
...you have ONE OF THOSE!?!?!?
duuuudeeee you're SO lucky.. do you have any idea how RARE they are???
man - once you drive a GTR with that green light on...
...man - it CHANGES how the car drives... MAJORly.
people look on yahoo japan for those al the time - they only come up once a year... kansai made a certain number of them and once they were gone...
..that's it... there's no more left of them.
i can't beleive you have one!!!!!!!!!
holy crap..
haha, okay you know what it does?
eps.......
you should just leave
on a serious note i beleive it does the following
Specs:
1、Eliminate 180km top speed limiter
2、Shift rev limiter timing
3、Eliminate boost limiter
4、Modification of fuel correction map and Ignition map
5、Change quorum (k)
6、Change lattice of the map (RPM, injection time)
7、Modify every correction points
same thing to this?
http://www.skylineowners.com/forum/showthread.php?t=137917
Edited by Clutch
eps.......
Specs:
5、Change quorum (k)
same thing to this?
http://www.skylineow...ad.php?t=137917
okay cheers, that little box does all that?
i thought the computer would do all that?
clutch is saying it could be a piggyback to your ECU or something like that..
personally i think it's a fluxcapacitor
lastly, clutch... bro... i thought we were making progress...
....the cease fire is hereby off bra.
you better leave, or things could get.... ugly...
*produces a butterfly knife from my pocket*
holy crap..
:rofl:
am i the only one that is thinking of homer simpsons dream when he's trying to invent things???
"HOMER!!!! thanks to YOUR invention, EVERY HOUSEHOLD IN AMERICA is going to need 2, or THREE of these things..."
"can i see it?"
"haa haaaaa What do YOU need to see it for homer? YOU INVENTED IT!!!!!! YOUR GONNA BE RICH!!!!"
lol
that's what Homer invented.
and hewe - yes.
that's a flux capacitor...
okay serious business...
...being that it's located in the BOOT of the car.. i would be inclined to think it's something lame like an FM expander or soemthing that does something to the audio...
...then again, being that it's from garage Kansai... it COULD be a piggyback ECU that bypasses limiters in your car, like speedcut/boostcut / remap fuel etc for "Track" time
....it could also be a resistor for the atessa system (push the button, make it a rear wheel drive car)
only way to truly find out - is either google the part serial number... or browse kansai's catalogue...
...OR... fix your big bearing... and drive with the button on
clutch. ceasefire is on. i love you again. lol
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
