also before you have a go, it might be worth checking the bushes in the rear hubs(where the links connect to). Just put the car up on stands and hold the rear wheel at a quarter to 3 and see if you can make the wheel move. If it moves at all there's more than likely some wear in the hub bushes, and probably some in the hicas if its stil there. I replaced all those bushes in a GTS4 a while ago and you could feel the difference when driving once they were all replaced. the car felt very planted and no more squirming.
  • 2 years later...
Ok, so the subframe bushes are on the way out on my gtr, I have been doing a lot of searching and reading on here. I'm just not sure what sort of bush I should be buying. Thinking of getting the Noltec/Whiteline ones. If you have changed your bushes what have you changed too and what are your thoughts on the brand you have chosen.
Also are the nismo ones any good?
Thanks
Andrew
Which and what type did you end up getting, mate?
I can't decide if I want to use PU bushings or Alluminium bushings.
  • 2 years later...
Thread dig!
Just done the driftworks solid alloy subframe and diff bushes on mine. Rear end feels good. It does create a fair whack more NVH though. Not as hard of a job as everyone makes it out to be
depends on how you do it. if you just left the casing in and used some dodgy solid setup then yes its easy, but if your doing a complete replacement including outter housing, its a kunt of a job to try to do at home. as I am finding out right now..
up to the part of trying to put the new ones in.. seems impossible looks like they can only be pressed in. left them in the freezer all night, thought id be able to heat up the housing, use grease and tap it in level with a sledgy, but no go..
I've pressed bushes in before by making a jig. What I did was get a thick steel plate with a hole in the middle some thick heavy duty stainless cable and other bits and pieces. You will not get them in by hitting them. What I done was use the jig to help pull them in while I hit it with a mallet. What you're trying to make is the opposite of a bearing puller. Its hard to explain but essentially some sort of jig to pull the bushings in while you hit them and tighten your jig as you go.
This is one of those things I would start doing my self. If I failed, I would load the subframe into the ute and drive it to a shop to have the bushing pressed out and new pressed in. Then reinstall the diff. FAR cheaper like this. I actually bought a subframe and have been changing the bushes on it and when I have time I'll drop the old and fit the new in.
Yeah thats similar to how I did the rear diff bushes. I had a quick go the other day at pressing the bushes out but I really haven't had time to have a proper go. They seem to be in there awful tight lol. Will cut the rubber bits out and just cut them out I think. Seems the easiest way
Sacrificial screwdriver and a big hammer. Keep hitting the bushing shell until you think it's never going to move. Then hit it harder and a little more. All of my mates have used this technique and it works every time but requires a lot of belting the piss out of it.
was a bitch to take mine out.. the casing had rusted into the subframe (I think my car was submerged in the ocean, it's got more rust than a commodore VN)... blow torched it, bashed it, air sawed it, you name it...
Eventually got it out, but man it was a mission... getting the subframe bushes in was pretty easy.. just use a large socket and bashed it in with a hammer and some grease.
@ sargeRX8
thanks yep I did try that, I got a half inch booker rod and high tensile 50mm nuts, 8mill steel plate, washes and cups and tried to pull it in.. with a pair of 600mm long 30mm spanners with silcon spray and tapping them in...added they had been frozen for over 24 hours.. but still..
bent the cups and plates, and one of the spanners, ran out of puff after I had bent everthing I had to take it to fulcrum to get them to press em in, even they had to hone the sleeves to make em fit. they spent 2.5 hours tryin to get them in on the press and charged me extra for it.
I used whiteline bushes.
@ GTSboy, yep couldn't agree more.. press in is the go.
I guess if the car had been done before previously and the sleeves had been honed already you may get them in with a pull tool. but if its the first time, and they are whiteline items, you will need a press.
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
