  • Replies 81
no real information to update...
your welcome Charles
and Carlo they are top feed high imp, Heslo has just bought a set so somehow they must suit RB26dett's
as soon as the supplier puts together our price's i will update i do have small update he told me today he also sells fuel pumps and gave me retail prices on them, unfortunately i left the paper work at work but ill go from memory
Bosch 044 $215
Bosch 040 $187
Walbro Int. $136
Walbro Ext. a little dearer than $136 but cant quiet remember he will supply me with new group buy prices on the fuel pumps also
all items pumps and injectors come with a full 12 months manufacturer's warranty and 100% authentic no Chinese copies
probably not PM sent i may extend this GB as i don't want to rush information but i wanted to get it started
and i will make a thread in the GB section and put a link for everyone to go register on
Hmm i found this bloke on EBAY, looks like he also sells Siemens 890cc Top feed Low Impedance EV1 Injectors for $79 each.
Following Stats:
Static Flow Rate: 83.2 lb/hr = 10.87g/s = 888 cc/min (+-/ 4%)
Dynamic Flow Rate 2.5ms PW @ 100Hz: 19.5mg/pulse (+/-4%)
Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
Spray Pattern: Pencil
Connector: Minitimer (Bosch EV1)
Only downside i could see here is you would need a 14MM fuel rail.
Edited by ZED X
hahahah did you note the seller, did you note in post #1 where i said parts are coming from :D
and RB20,25 want high impedance GTR use low impedance and Heslo didn't get back to my txt
and the 80lb Siemens injectors on his webshop are dearer than he quoted us already :D :D
Steve - what size RB25 injectors can you get? Currently using S15 450'cc and dont want to go up too big, ie 550's, 600's etc
Whats available?
cheers mate..... if i upgrade the injectors I'll definitely (finally) bolt on the exh.manifold and perhaps look at a greddy-copy intake plennum.
one last tune perhaps :)
this i might be interested in steve.
aye - is it wideband, and compatible with nistune/pfc?
These innovate units work with nistune for sure, and look quite decent
http://www.innovatemotorsports.com/products/db.php'>http://www.innovatemotorsports.com/products/db.php
http://www.innovatemotorsports.com/products/lc1.php'>http://www.innovatemotorsports.com/products/lc1.php
Thats what I'm semi keen on... does that one talk to nistune ?
-D
6. What Wideband support is there?
Currently NIStune supports the following Wide Band units:
TechEdge 1.5 and 2.0
http://www.techedge.com.au
Innovate LM1 and LC1
AEM UEGO
http://www.aempower.com
Zeitronix
http://www.zeitronix.com
PLX Devices (R Series)
http://www.plxdevices.com
MOTEC PLM
http://www.motec.com.au/plm/plmoverview
Just Another Wideband
http://www.14point7.com
VEMS Wideband
http://www.vems.co.uk
DLP Design A/D Converter
http://www.dlpdesign.com/usb/io8.shtml
These units connect to your laptop via the serial port (or USB port when using serial-USB adaptor). These units output data to allow NIStune to monitor your Air Fuel Ratios from their sensor, and some produce auxillary inputs for connecting other sensors which can display and log inside NIStune.
NIStune provides several internal utilities to make the most of your Wide Band
- Dyno Mode AFR graphing against RPM
- Real time AFR and auxillary map display (minimum AFR, maximum AFR and current AFR against the fuel map)
- Logging and playback of AFR
yes the unit is wideband
looking into if its a nistune compat but i dont see why as it has its own box to read the O2 sensors that comes with it
oh :( the whole kit the guage i posted and 02 bit is $504
that below is the rest of the kit
http://www.dynojetwb2.com/images/products/wb2_kit_1.jpg
Brendan if you only want 500cc i can get the 52lb/h injector there around 535cc
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
