  On 13/02/2011 at 11:02 PM, MaTBoY said:
oooo i like photo comps!!! :D
nice lighting there. single flash? Softbox?
Cheers, single 580EX II fired with pocket wizards through a white bed sheet hanging of a clothes line :)
This was shot in my back yard, about 5 meters behind him is a garden and a fence
70-200 2.8 at F8 and around 100mm
No doubt they are the best out there. Just that I have been so busy lately and havnt even used it or tested it :(
Hopefully this week i can.
On other news im not liking the 7d in regards to holding it and how its moulded. Feels weird compared to my 5dm2 and my hand gets more tired.. Sounds funny but I like the 5dm2 instead lol..
Should have just got another 5dm2.. sigh
Edited by siddr20
How do you find the image quality of the 7D vs 5D Mk II? I realy need a second body and for what I do (mostly motorsport) the 7D on paper at least seems like a good coice
The other option is a 1D Mk 2n. Curently I shoot everything on the 5D II
To be honest I haven't taken many shots with the 7d. Bought it as a backup body and will use my 5dm2 90% of the time. Ideally I wanted another full frame so both bodies are identical etc.
But to answer your question the 7d will be more suited for you esp for motorsport photography. Better fps, better focus systems/points and most importantly for you its a crop body so you get more reach.
As soon as the 5dm3 comes out I will be selling the 7d. Feel like selling it now as I dont like holding it even with a grip. The whole body seems heavier than 5dm2. Not sure if its just me or if it really is heavier in specs.
For now will just use it as backup camera.
But what I have read on paper the 5dm2 is much better at higher ISO's..
I say go for it, or wait till I sell mine when the 5dm3 comes out lol..
Edited by siddr20
  On 12/02/2011 at 5:58 AM, MaTBoY said:
one for TEZZAH
Damn that's amazing, photos like this really got me interested in photography.
The local pool built some water spraying/splashing facilities, which I thought were quite cool.
thanks man :) Appreciate it! I'm currently using that one as my wallpaper!
Had a shoot last night with a rally replica Evo 5. Looked pretty coool cruisin through the mountains. Sounded pretty cool too. I've got 2 more SAU cars to finish before i get to the rest of these, Expect more from this set later in the week, or early next week! Here is something to get you interested though :P
I looked at the prices of the 7D after you where telling me you where interested in one for a backup and its a fair price difference between it and the 5dmk2! Its a shame it doesn't "feel" right after using the 5d as i too was almost thinking of downgrading to one to save a bit of money :(
The main thing im worried about with the 7D is a noticable drop in immage quality and sharpness from the 5D. There is a lot of pixels on a small sensor there...
While im here, heres a few from the weekend:
Full gallery from this event here for those interested: http://nextgenphotography.zenfolio.com/f1056799984
Should have saved up a bit more and just bought your 5dm2.. oh wells.. will sell the 7d as soon as the 5dm3 comes out.
Btw still havnt used your flash lol.. still sitting there in box :P
Edited by siddr20
Kory shoots with a 7d. Might be best to ask him since he does motorsport as well.
i've played with Kory's 7d and it's perfect for motorsport. If i didn't have nikon lenses I'd get a 7d in a heartbeat. it's tracking ability and speed is amazing. coupled with some good glass i doubt you'd notice much difference in quality. it's a little beast. I even like holding it :P it's a good size and shape to hold while on the move.
matt, when you stack these in photoshop how do you blend the layers? lighten/darken?
also, maybe erase the background in all but one layer. can see where the camera shifted slightly between shots.
damn good work tho, love your style. im still keen to try this style out one day, need to sort out a lightbox of some kind.
usually lighten and mask. i will be retouching this one. the background is lit differently over a couple shots as I was using 2 flashes at a time. still, there's a few things i need to do on this one to clean it up. need to finish the other 2 cars first though before i go back to it. thanks for the tips though :) I thought you'd appreciate this set more than most ;)
Thanks for the comments on the lizard shots, guys!
Man, only one of my shots from that shoot on Sunday night turned out well, so here it is:
Most of my other ones were underexposed and/or blurry, and at the moment I really CBF working to bring them back to something worth posting.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
