I always shoot in full manual
First time shooting at night with my prime lense. Had some issues with focus but these two seemed ok. Might be how they are resized like you said. The lense is pretty sensitive to what is in and out of focus but so I may have been just a bit off
the second one is in focus, the focus point is the rear windscreen tho.
with the first one turn the car wheels so the face of the rim is facing the camera instead of the tyre ;)
its not as in focus either. maybe try stopping the lens down a bit more too as 1.8 open wide isnt always that great for car shots as the DOF is a bit too small except for detail shots.
still pretty cool though, wish i wasnt so lazy keen as to do night photos but never have the motivation to get out there and do it, lol.
Edited by Jay019
Ah ok, Maybe thats my problem
Last time I took car shots at night they had alot of noise and I realised afterwards I had my ISO right up (whoops). So the photos looked alright on the little camera screen but as soon as they went on a laptop there was far to much noise in them. Beginner mistake, something I should have relised but oh well...
I Think thats why I was overcompansating with the lowest ISO I could use and adjusting the apature right down So I wouldnt have to drop the shutter speed (If I'm further off doing the right thing then I relise here I'm happy to take some constructive critisism, ISO was at about 400, Apature at 1.8 and shutter speed was between 1/20 and 1/40 or around abouts. Like I said but I overcompansated with the ISO cause of last time)
Ill put another 2 photos from the night up. The Lighting in the Skyline one isnt right, but Its a bit better focused. The one of the monaro I think suffers from the same issues as the above photos but not as bad (now that you guys bought it to my attention lol...)
Like I said I'm open to critisism, I dont mind these photos but I know there a long long way from alot of you guys in here. But I'm willing to learn and try out different shooting methods. I like to think I'm slowly improving lol
Thanks
P.S. That first photo of my car where you said the wheels are facing the wrong way..... I was parked Illegally in the middle of a road so just ran out to grab a photo before anyone came haha. Should have thought about the angle of the wheels in alot of these photos but I was being pretty lazy on the night
Edited by 89CAL
Here's some I took at Circuit Club's Twilight event last Thursday night.
Here's Matt:
Some random S2k in the next garage:
A really nice Evo also sharing the next garage (and "Aggroman" Dave in his R34):
"Pezhead" Eric's engine:
And Dave's R34 again:
along with the man himself (kinda :P ) as well as Eric giving Dave some pro tips:
Sorry about your loss mate.
We've had her about 7 years and she was living in a friends front yard, so she doesn't lay too often these days. Still get a few, if we can find them :P The dog usually follows her around, they're good friends! Lol
Damn I'm hot in a helmet. When you can't see my face i reckon i have a pretty good to average looking face ;)
Hahaha - for a second there I thought you had some crazy weird fluffy animal hanging from the front mirror :P
Ps two taken during our Simpson Desert trip last year:
Dingo Tracks by ZENN0N, on Flickr
Staring into the desert by ZENN0N, on Flickr
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
