hey guys stripping a series 1 R33
list and prices as follows:
RB25 gearbox - $1000
Headlights - $50 each
Tailights - $50 each
Bonnet - $100
Boot - $80
RB25 low on compression, number 6, no turbo or coilpacks - $600
AMG 18x8, okay tread - $400
Front guards - $50 each
Front bar - $50
Rear bar - $50
Front and rear seats, very good condition (include genuine Skyline floormats) - $300
Front Mount kit, good condition, no leaks, includes pipe work - $250
Exhaust 2.5in, stainless dump through to sick twin cannons - $150
Stock 25 turbo, good condition - $200
Radiator, good condition, no leaks - $100
Whiteline Front Strut Brace - $70
Doors ( drivers missing handle) with glass and insides - $60 each
Mirrors - $20 each
5 stud conversion including brakes, rotors, calipers, hubs, knuckles and rear lower control arms - $900 ono
Stock struts and springs - $150
33 rear cradle and diff - $300
RB20 computer, splitfire coilpacks and loom - $400
If someone wants a rego able (its got copshop defect) shell, buy it now with out motor box or loom for $1800 with everything else..
If you want anything else, just PM me or 0405 523 293 (if i dont answer send a text)
Located in Golden Grove area
can send/deliver...
https://www.sau.com.au/forums/topic/352479-r33-5-stud-motor-etc-etc/
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
