1999 Nissan Silvia S15 JDM Spec R
ENGINE:
• SR20DET (Rebuilt 13,000kms ago at 89,310kms) Have receipts
• 102,310 kms now on body
• 5 Speed S14 Box and Tailshaft
• Exeedy Heavy Duty Clutch
• Lightened and Machined Flywheel
• 3" Exhaust with High Flow Cat and Polished Cannon
• Apexi Pod Filter
• Brand New Bosch Z32 AFM
• Polished 3" Aluminim Intake pipe
• Re-Built Standard Jap Spec S15 T28 Turbo
• Standard Manifold
• Brand New 740cc Nismo Red Injectors
• Bikirom Piggyback ECU Fully Tuned
• Bosch Intank 040 Fuel Pump
• Splitfire Coilpacks
• GReddy Spec LS Intercooler Kit and piping
• Serviced and Oil change every 5,000kms
• New Bosch Double Platinum Spark Plugs
EXTERIOR:
• Pearl White Factory Colour
• Fully De-badged
• Sunroof
• Spec R Standard Body kit
• Aftermarke tHID Headlights
• Rear Guards Professionally Rolled
• Night shade tinted headlights and tail lights
• Tinted Side Indicators
WHEELS/SUSPENSION:
• 17x8 + 17 offset V35 Skyline Wheels painted Black with Gloss Finish
• 30mm Spacer Plates on Front, 25mm Spacer Plates on Rear
• Near New 215/45/17 Hero H1 Tyres on Front 90% Tread
• Near New 215/45/17 Kumho KU31 Tyres on Rear 80% Tread
• Brand New BC Racing BR Series Coilovers all round (8kg front and 6kg rear spring rates)
• Ikyea Formula Tie Rod Ends
• JJR Adjustable Camber Arms
• Under body chassis brace front and rear
• Tein Strut Brace Front and Rear
• Standard Spec R strut brace in the boot
• DBA Slotted and Vented Rotors Front and Rear
INTERIOR:
• 7" Touch Screen DVD Player with Ipod Connector and USB
• Stock speakers front and rear
• GReddy Chrome Sphere Gear Knob
• Razo Full Auto Turbo Timer
• T20 Darkest Window Tint all round
• Ice Cold Air Con
• Mongoose M80 Immbolisor and central locking
• Rego until Jan 2012
• RWC will be supplied upon sale after deposit is put down
• No low ball offers
• Located on Brisbane Northside
• Call Mick - 0438 860 307
$19,000 ono
NO SWAPS... CASH ONLY
https://www.sau.com.au/forums/topic/352553-1999-nissan-silvia-s15-jdm-spec-r/
Just had full Gearbox overhaul: spiggot bush, clutch plate, rear main seal, redline shockproof oil installed...
Brand new Rocker Cover Gasket kit installed also..
Drives like a new car...
  • 3 weeks later...
  • 5 months later...
  • 1 month later...
  • 3 weeks later...
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
