hey up for sale is my 1998 model r34 skyline gt non turbo 4door skyline P plate legal,
Manual gearbox very hard to find 4 door manual
has 77,000km on the clock car runs fine never missed a beat, just done service say 1000km ago with motul oils, allways ran on 95-98 occtane nothing but Caltex. ive done abit of mods in the last months such as
HKS COILOVERS HYPER MAX, R32 GTR WHEELS, NON HICAS REAR END, SPLITFIRE COILPACKS, CUSTOM MADE EXTRACTORS, R33 NON ABS LSD DIFF, FRONT HEADLIGHT EYE LIDS, HAS SOUND SYSTEM PIONNER SUB AND AMP AND A KENWOOD DECK, XENONS FACTORY GAS HEAD LIGHTS, SUMMIT STRUT BAR (FRONT, also comes with stock shocks,springs,WHITELINE SWAY BARS FRONT AND REAR AND A FEW MORES BITS AND PIECES
$11,000
rego till feb 7th 2011
please call me on 0457 245 473
selling cheap very hard to find in this condition
more pics coming
Edited by pj-33
https://www.sau.com.au/forums/topic/352564-r34-4-door-gt-jap-spec/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
