hey up for sale is my 1998 model r34 skyline gt non turbo 4door skyline P plate legal,
Manual gearbox very hard to find 4 door manual
has 77,000km on the clock car runs fine never missed a beat, just done service say 1000km ago with motul oils, allways ran on 95-98 occtane nothing but Caltex. ive done abit of mods in the last months such as
HKS COILOVERS HYPER MAX, R32 GTR WHEELS, NON HICAS REAR END, SPLITFIRE COILPACKS, CUSTOM MADE EXTRACTORS, R33 NON ABS LSD DIFF, FRONT HEADLIGHT EYE LIDS, HAS SOUND SYSTEM PIONNER SUB AND AMP AND A KENWOOD DECK, XENONS FACTORY GAS HEAD LIGHTS, SUMMIT STRUT BAR (FRONT, also comes with stock shocks,springs,WHITELINE SWAY BARS FRONT AND REAR AND A FEW MORES BITS AND PIECES
$11,000
rego till feb 7th 2011
please call me on 0457 245 473
selling cheap very hard to find in this condition
more pics coming
Edited by pj-33
https://www.sau.com.au/forums/topic/352564-r34-4-door-gt-jap-spec/
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
