Hey guys been helping my brother out with finding a clean R32 GTR. He wants to build one so we are looking for a good base to start from.
As some of you would know this is not an easy task. Have looked at around 12-13 so far in about 8 months...Anyway, long story short we have found a black one that is completely imaculate. No rust at all. Engine wise, interior and body wise... its perfect. Well almost, the only thing is that the car has been involved in what looks to be a minor accident (passenger side rear quarter)The owner has kindly allowed us to put it on a hoist and upon doing so we saw that there is no damage to the chassis rails but there is a slight crisp in the wheel arch which shows that there has been some minor panel beating in the arch itself and it looks as though the guard lip has a little bog on it..The dilehma we have is whether to keep looking or to buy. What do you all think? From experience with R32 GTR's their are many many more bad examples than good ones. The damage is cosmetic not structural and otherwise the car is perfect... 95,000 genuine kms with log books, receipts from japan and Australia.Some advice would be great Ross
https://www.sau.com.au/forums/topic/352566-gtrs-with-previous-damage-history/
If it was fixed properly there is no reason to not buy it. Should be fine
Thats what I told my brother.
Hes pretty fussy but, If you look in the right light at the line around the wheel it has been a little lost in some places probably because the panel beater couldnt get it perfect when it was beaten out with the bog.
If the job has been done properly I think is the major aspect..
As above - if it's been done correctly, there is no issue.
Get it checked out by somewhere like Micolour if you are concerned about the job etc.
+1
If your worried get it checked by Micolour. Absolute genius when it comes to 32 GTRs.
Most cars have been in some form of minor accident by that age, whether it be parking/shopping center-speed incidents or something more serious. If it's just one rear quarter panel that's been repaired, then that'd be a pretty minor accident. If everything else checks out and the very minor blemish in the repairs doesn't phase you too much as others have said there's no reason not to buy. There will be plenty more far dodgier examples around.
Thanks the advice guys.
Well i just wanted to clarify as non accident car, no previous damage history are thrown around alot when looking for a car. I know it may just be a selling point and I know that alot of it is not true but just wanted to see if there was any truth in buying car with an accident history.
I guess it comes down to personal preferance. R32's are alot harder to find in good condition than most other skylines. so it's more so the point whether to keep looking or not. If it where a. R34 GTR I think we would have kept looking.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
