Wrecking R33 Gtr Vspec '96 70,000Km
  • Replies 58
Parts still available, will do good prices
Brake Booster (like new)
Brake master cylinder
Clutch Master Cyliner
Clutch Slave Cyliner
Std Flywheel and clutch
Rear Active LSD Diff
Rear CV's
GTR Attessa Pumps
Front ABS sensors
G sensor unit
rear yaw sensor
GTR tranfer case
Passenger dash Airbag
Climate control unit (like new)
Carpet
Dash pad
Heater core
A/C servo's
Attessa ECU
Fuel ECU
Kenwood Factory Amp
A pillar covers with std Kenwood tweeters
Rear Kenwood Splits(nissan) Carbon fibre cones
Rear parcel shelf with factory Kenwood covers
Center console
Front left Suspension upright, hub , knuckle
Rear upper suspension arms
Front Sway bar(good for twin setup)
Factory loom (very good condition)
Any other loom you need
Fuse box(front, interior and rear)
GTR strut top brace(front and rear)
Roof Linning
Drivers door
Electric window motors
Electric window switches
Central Locking relay
Exhaust 3"x2 into 3.5
Std exhaust manifolds
Various turbo pipes(water, oil)
Rear drivers side tail light
GTR Side skirts
All glass
B pillar interior plastic covers
Door scuff covers
Peddle kit(good for auto to manual conversion)
Fuel tank
Fuel cap lid
Air bag ECU
4 door tail lights
4 door rear center garnish
GTR Skyline rear center garnish
GTR rear boot lock
G4 R33 GTR Adj suspension
Sail panels
STD airbox(no snorkel)
Std AirFlow meters(no mesh)
Apexi AFM elbows(for pod filters)
Turbo timer
Apexi RSM
Glove box
Roof lights
Shell (complied)
Plastic panel under wipers
Space Saver Wheel
rear boot struts(heavy duty)
Lots of other lines and hoses in the engine bay
Matt
0413023669
  • 4 weeks later...
  • 4 weeks later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
