Sorry, told a furfy about the build date on the jap plates, sorry. with the vin though I can confirm the build date. I have original books with mine, that also document build and delivery dates.
for '95 ECR-33, numbers should be between the following:
051880-063435
100001-100019
101001-101987
If its different, if you tell me what it is, I can tell you the build year, as I have jpgs of the different models and corresponding engine numbers for different jap cars.
Yes an auto ECU will run a manual car. A manual ECU will not run an auto car. In answer to the differences between the S1 & S2 ECU's, has anyone thought of the fact that S1 run an ignitor on the engine itself, whereas the S2 have the ignitor built into the ECU. Surely that should be a main difference. But if people have responded and said that S1 and S2 are interchangable, then it must work. Realistcally, you are better off saving the money buying another standard ECU and buy a second hand Power FC. They have come down to about $1100.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
