Hey guys
Just thought I would throw this up here for personal opinion
I'm just tossing up idea's on whats going on.
The problem that I am getting is that the engine doesn't like timing.
Its running 17 deg advance at 7500rpm. anything more and it wants to ping
Ran BP ultimate on the day. Bad batch of fuel would ping like crap coming onto load.
The problem that I am getting is that it wants to ping top end.
My setup is this:
r33gtst manual
155-160 +-5 across all 6 when warm
580cc high flowed sr na injectors (tested, spray pattern perfect all, all spraying same amount when tested)
Plazmaman Plenum
3" stainless intercooler piping
600X300X100mm intercooler, kls power spirit
bosch 040 in tank pump
splitifre coil packs
standard fuel rail and fuel pressure regulator
3.5 inch turbo back stainless mandrell bent exhaust.
3.5inch cat, 100 cell brand new
6 boost manifold,
Tial 44mm External gate
GT3076R
.60A/R anti surge front, .56 Wheel trim
.82 rear, .84 wheel trim
external gate 4 bolt rear, 5007 3076R
Testing done so far:
Pressure drop of intercooler. .5 of a psi drop from turbo side to inlet plenum
Exhaust pressure is only at 3 psi at ful noise
De-carbonise tops of pistons/cylinder head clean (did f**k all)
Ive got this thing tuned with the aid of Exhaust Gas Temperature senders on each cylinder, they are all on par and off the top of my head should be somewhere around 650 degrees (don't quote me)
Ive got two things that i want to address.
does that dyno sheet look to be about right?
and apart from the heat on the day (35 degree's in the dyno room) would there be any other reason to blame something else apart from heat soak for this problem
Discuss.
Edited by sriver killer
https://www.sau.com.au/forums/topic/352597-critique-my-dyno-graph-gt3076r/
One thing to try, get a long piece of pipe, put it between the pod and the turbo and see if you have the problem when you are ingesting room temp air rather than post radiator air.
bit too late as it is off the dyno, i honestly didn;t think it was goign to make that much of a difference,
seeing as cold air intakes only give at best 5kw atw gain.
Just saw you have high flowed injectrors......eeek. Did you work out which cyclinder is pinging? Then I would swap injectors and see if it follows. I have not had a good set of high flowed injectors yet. Can you borrow a set of nismo's?
Also the pod in the engine bay is sucking a lot of hot air prob over 45degrees that day...would kill power. What was the intake manifold temp?
The fact its doing it up top is whats making me think its the charge temps. Be it timing or the CAS I would expect it to be more likely to occur when coming onto power, or if it were electrical and up top I would expect it to be erratic.
This seems more consistent with poor charge temp due to the position of the pod. Dont forget as revs rise under bonnet temps soar as the manifold gets hot and emits heat, and the clutch fan pulls more hot air through the rad which has only one place to go, the big vacuum right besides it.
I'm thinking along the same lines.
Have a look at this dyno sheet of my vehicle, doing consecutive power runs
under bonnet temps would have rose something chronic
would it be enough to still cause that much power loss, we are looking at 70whp there, that is a bit much isn't it?
even at 380whp i thought that this setup would produce more than that ( done when intake temps are low)
Ive got one of those KLS power spirit intercoolers,
They Flow alot, and have quite large fins,
previously i had a really dense intercooler.
got me thinking that in 36 degree's and with my pod sucking in All that hot air the thing wouldn;t really be cooling it in a dyno that has 36 degrees ambient temp
It has been tuned for 11:1 AFR's so some of the power can be found by pulling out some fuel and taking it toward 12:1 or wherever it makes best safe pwoer.
The richest run (10.8) to the leanest run (11.2) on that dyno makes about 45hp difference at 5600 rpm.
The KLS cooler looks like a run of the mill china job. Decent enough for what your doing but hardly the bees knees.
Honestly, chuck it back on the dyno with your pod hanging out of the bonnet rather than under it. Instant answer for that one, yet guaranteed the intake temp on that would be 60 degrees on its own BEFORE its compressed IMO.
checked your fuel filter lately? mine was blocked and was causing mine 2 lean out on dyno aswell. replaced pump first cause it was a bit noisey, but later decided to pull fuel filter off and i couldnt even blow thru it. problem fixed after that. also try a different CAS. mates 32 was making 450rwhp then next run 350 then 370 etc, replaced with a dif CAS and problem solved.
17 degree of timing is a good amount on full load. Perhaps use a timing gun and see what base timing you're running.
On my old car, I found out the base timing was set at 21 degrees, don't ask me why.. so I dragged it back to 15. Even on full load, with a tiny ass turbo @ 1.3bar, I only could dial in 12 degrees on full load, and 14 around red line.
I would personally lean it out a tad, seems quite rich and back 1~2 degrees of timing on load (usually rows 16/17/18)
Pretty sure my car only ran about 17 degrees of timing at 7500rpm. That side of things sounds normal.
376hp @ ~18psi sounds perfectly normal to me for a 3076R.... I'm not sure what your expecting/complaining about.
Thats what I was thinking too, glad I asked... I thought I might have been going mad or something.
I suspect there is no problem, the car is making what you'd expect on that boost, with that fuel, with that turbo :)
my 2L made 374hpatw with 21psi with 17˚ timing at 6800 on bp98. i'd say the figure is about right.
Hey guys
My setup is this:
r33gtst manual
Plazmaman Plenum
6 boost manifold,
GT3076R
Discuss.
That is an interesting boost line you have there mate...
Where are the rpms on the graph?
And I've never seen a dyno graph with kmp/h on the bottom before lol
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
